when i try and duplicate a section of midi within the midi editor window, many times, the first several midi notes or even first several chords (if I'm using a piano) will always be left off the duplicate. I'll then need to manually go in there and pencil those notes back. It's like the copy function doesn't copy everything. I can't seem to find out why this happens. I highlight the whole bar of the midi i want to duplicate, click copy, then duplicate, the result is a duplicate but it's missing the first few notes of what I just copied.
has anyone had this issue or have a fix? maybe i'm copying incorrectly but i can't think of how else to copy.
Mac OSX 10.15 Catalina Pro Tools 2020.09.1 2020 Mac Mini 3.2 Ghz i7, 32GB Ram UAD Apollo Rack Thunderbolt UAD Satellite Quad Glyph Studio Raid SSD |
Does anyone have a possible solution for this? Or is this just a bug? Thanks in advance.
![]() Quote:
a) quantize your MIDI data, forcing the note starts to the grid, (you can just quantize the first downbeat if you want) or b) offset your copy/duplicate selection range by a small amount, by this I mean, select the whole range you want, but start 1/16th note early, and end the selection 1/16th note early as well. This way you will catch all the "note on" data but still end up with a loopable selection. By the way ProTools associates the corresponding "note off" command with each "note on" command, so you don't have to worry about catching the tail end of each note. |
Duplicate MIDI notes? | Monaco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 10-08-2013 01:29 PM |
MIDI Editing duplicate notes | AMcG | Pro Tools 9 | 1 | 10-26-2011 07:28 AM |
Duplicate MIDI notes with AXIOM 61 problems | proverb18 | MIDI | 0 | 09-07-2007 09:56 AM |
MIDI ghost/duplicate notes problem...HELP! | vocalvoodoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-02-2005 08:12 AM |
How do I remove duplicate MIDI notes? | Rob Ruce | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-11-2003 02:51 PM |
