Old 08-03-2012, 01:57 AM
sammyfarr sammyfarr is offline
Default HDX Madi with SSL Alpha-Link AX
Hi All,
ive had a look around the forums but cant find anything conclusive...
im looking at buying this combination as it seems the cheapest way to get an hdx rig with 24 analogue and digital i/o. I wonder if anyone has this running and if there are any issues/complications that are worth considering?
somewhere in one of the forums i read that pro tools cant compensate for input delays created by non avid converters, ive only ever used digi or avid converters so dont know if this is an issue or if theres a setting to overcome it?
any advice would be greatly appreciated!
thanks
Sam
Old 08-03-2012, 03:21 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: HDX Madi with SSL Alpha-Link AX
Pro Tools will compensate for your convertors. The values it will compensate for however will not be your 3rd party convertors. It will see it as an Avid interface and by default compensate for those values.
Chris
Chris Lambrechts
Applications Specialist- Live Sound
Old 08-04-2012, 01:23 AM
phatbeatstudio phatbeatstudio is offline
Originally Posted by sammyfarr View Post
Hi All,
thanks
Sam
Well even if it didn't compensate for them automatically ,I assume you could do it manually . Wouldn't the delay usually be the same so if you figured it out once then rinse and reuse. just like a condom well maybe not on second thought.
Old 08-11-2012, 04:11 PM
Chris
Thanks Chris, that's what I thought. Is it possible to adjust the amount p tools compensates?
Cheers
Sam
Pro Tools 10 and SSL X Logic Alpha Link Madi AX Basslab macOS 0 01-25-2013 09:07 AM
PT10 with XLogic Alpha-Link MADI AX? Riversyde Pro Tools 10 0 02-16-2012 02:53 PM
PT 10 + SSL Alpha-Link Madi-AX and MIDI bfire Pro Tools 10 1 01-14-2012 04:42 PM
does Alpha-link Madi works with PT9? coloquinte Pro Tools 9 21 07-11-2011 11:09 PM
HD PCIe with SSL Delta link MADI HD Alpha link MADI AX Juraj Bernáth Pro Tools TDM Systems (Mac) 3 09-10-2009 07:13 AM
