Old 07-13-2012, 04:43 AM
andreconde andreconde is offline
Default Control 24: Preamps not working and Peak leds are lit at all times
I recently bought a Control 24 and its preamps don't work.
Peak led is always lit red, from the moment I turn the console on.
There's very low signal coming into Pro Tools from the channels I try to record. I mean... I can see very low signal but not hear a thing.
I live in an island in Portugal and there are no techs available. I really need some help to try to sort this out on my own.
PS: If I disconnect TB6 or TB7 (connections for the mic preamps sub-regulator board I believe) from the power supply the Peak leds come to normal (they are not lit anymore) but now there's excessive weird noise from the moment I turn the console on.
PS2: C20 capacitor was already exchanged but nothing changed.
Does anyone have experienced these symptoms before?
I'd be much appreciated for any help.
All the best,
André
Old 07-13-2012, 01:36 PM
Default Re: Control 24: Preamps not working and Peak leds are lit at all times
Update:
It seems that the culprit is the sub-regulator board for the preamps.
Disconnecting this board and connecting the rails directly to the PSU puts it to work, with what seems to be a normal noise floor.
On the sub-regulator board, for each harness it reads GRD 10V -10V 10V -2V. This last value seems off to me. When connected directly to the PSU, the last value is -10V.
Does anyone know what's the actual function for this sub-regulator board? Lowering the noise floor for the preamps is my guess but I don't really know.
Will I be damaging the preamp cards running the power directly for the PSU without passing through this sub-regulator board?
To my knowledge, information about this is non-existent on any of Digi's websites.
Btw, the regulators on the sub-regulator board are: 1x LT1963A and 2x LT1175.
LT1963A: http://cds.linear.com/docs/Datasheet/1963afe.pdf
LT1175: http://cds.linear.com/docs/Datasheet/1175ff.pdf
Old 11-07-2014, 03:37 PM
beecher beecher is offline
I have the same prob on channels 1-8 but fortunately I don't use the inputs just for a controller. I do have noise in my headphone mix because of this. Were you able to fix the problem? I am thinking of just disconnecting from PSU.
Control 24 automation LEDs reversed JNS ICON & C|24 0 03-27-2010 12:00 AM
003 powers up with all LEDs lit and no control surface function tsvisser 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-26-2009 03:48 AM
Flashing Peak Lights - Control 24 Not Working davedanger ICON & C|24 0 03-26-2009 12:40 PM
MBox 2 LEDs not working / Pro Tools not launching georgepeter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 09-13-2007 04:08 AM
mbox - all LEDs (except peak, 48V & USB) on, not recognized Ortli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-15-2007 10:51 AM
