problem whit artist control
I have an artist control and mix artist but my computer does not recognize when I connect both to a router, not even the softwere of EuControl run-
When I connect a computer directly to my work without any problem if Anyone have a solution to this problem? is the last update you download from the website of Avid. My computer is a intel pentium pc with windows 7 ultimate 64 bit audio card 56 Focusrite liquid safire and I have pro tools 10. |
Re: problem whit artist control
Let me see if I understand...Your EuControl works only when is connected to the computer but not the the router? If that is the problem you may have to change the IP address of the control to DHCP. To do that press and hold the "TWO PAGE" buttons at the same time and hold the power button. When it turned on you will see a block that says "Use DHCP (Obtain IP Address automatically). If the block is unchecked please click on it and click on the OK button and turn on the control and re-start the computer. If the box if already checked then you will have to check the network card in your computer. Let me know and I will give you the steps for your network card.
I have kind of the same problem before but the control wasnt working when it was connected to the computer, your case is the other way around. Good luck |
Touching Artist Transport Freezes Up Artist Control in Logic | sonofmack | Artist Series | 1 | 03-13-2013 08:22 PM |
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control | lberrios1962 | Pro Tools 10 | 18 | 05-26-2012 12:51 AM |
Problem with Artist Control | somauki | Artist Series | 5 | 05-04-2012 12:51 AM |
problem whit rosetta and Protools interfaces | zubel | Pro Tools TDM Systems (Mac) | 4 | 05-09-2010 02:53 PM |
Help: problem whit quantize! Better choice for set up? | nanetto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-23-2007 03:52 AM |
