Old 04-12-2012, 01:39 PM
browniespeaks browniespeaks is offline
Default BUG? selecting midi track arms record for selected track
Could someone give this a shot before i start trouble shooting. If its a bug I wont bother. Did a quick search but things are pretty messy at the moment.
Presented after 10.1.2 Update Windows 7 SP1 system
Did not present on previous version
Single left click in title field of any midi track either in the edit or mix window causes track to record arm. Clicking record arm button will disarm the track but if you start recording it records new midi as usual. PITA
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Old 04-12-2012, 03:53 PM
mattpete's Avatar
mattpete mattpete is offline
Default Re: BUG? selecting midi track arms record for selected track
Hi Clifford,
We can't reproduce this in Daly City.
Matt Peterson
Avid Audio
Old 04-12-2012, 06:10 PM
thanks appreciated. I'm sure the standard stuff will fix it.
Clifford Brown III
www.brownaudio.com
Old 04-16-2012, 08:30 AM
Gorsat Gorsat is offline
I am seeing the same problem.
Select an instrument track and it will automatically be record enabled.
Screws up workflow and causes mistakes. Super annoying.
Never saw this until the 10.1.2 update (and I've been running all the updates since 9.0.2).
My system is a Win7 SP1 64bit.
I can't find any way to turn this off and since there is no documentation of it I assume it's a bug rather than a new feature.
Strangely, there's a thread one of the Mac forums about this same bug but in an older version of PT.
Anyone have a fix for this?
Old 04-17-2012, 12:53 AM
i have been just living with it tell i have the time and want to go ahead and make sure i have all my preferences saved some-ware before i trash them. That usually will fix this sort of thing. At least its consistent though. Put a post it on your monitor tell its sorted. If you get to do the recommended trouble shooting before me would you please post back how it works out.
Clifford Brown III
www.brownaudio.com
Old 04-17-2012, 11:53 AM
trash prefs and databases this fixed the issue. It also fixed the freezing redraw issue ive been having since 10.0.1
Clifford Brown III
www.brownaudio.com
Old 04-17-2012, 11:40 PM
Wow. That fixed the auto-record-enable for me, too. Thanks! I haven't had enough time to see if it fixed the UI freezing. I guess I'll have to make prefs & DB cleaning a part of my regular routine
Old 04-18-2012, 01:07 AM
haha but after re installing the driver set. i forgot to re enable legacy firewire drivers. oops dont forget that. Without that one i got CPU hold off errors.
Clifford Brown III
www.brownaudio.com
Old 04-18-2012, 07:32 PM
there is a link on my signature here for an app (Trasher) i created that you can run to make the process of deleting the prefs and databases much simpler. contains some extras as well, but this is the basis of the app.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I9 14900k
Win 10
Old 04-18-2012, 08:03 PM
will it back up my current settings?
Clifford Brown III
www.brownaudio.com
Selecting Instrument Track Auto Rec Arms Connor Pro Tools 11 1 07-26-2013 06:18 AM
Selecting instrument or midi track automatically arms record tunes7 Pro Tools 10 4 05-03-2013 02:51 PM
Shift + Option + Record Enable not working with MIDI and Audio Track selected, why??? enzomolinari Pro Tools 9 0 07-20-2011 07:00 AM
MIDI Input Problem - Selected Track vs Record Enabled salmonsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-28-2008 07:42 AM
record track un-arms after stop! soundwavve Pro Tools TDM Systems (Mac) 3 07-30-2008 08:16 AM
