Old 04-10-2012, 12:25 PM
fourthtunz fourthtunz is offline
Default Using carbon copy to move from macpro to a newer Macpro
Anyone tried this?
Using Carbon Copy Cloner to clone your current drive to the larger drive
in your new mac pro?
Old 04-10-2012, 12:38 PM
zoff zoff is offline
Default Re: Using carbon copy to move from macpro to a newer Macpro
Originally Posted by fourthtunz View Post
Anyone tried this?
Yes. Some new Macs might not work with the old OS. Try booting the new Mac from the "current drive" if it boots then do a clone. Boot from the clone then update the OS on the clone with a Combo Update.
If the clone method doesn't work, sometimes the old mac won't run the latest OS required for the new mac. Use Migration Assistant.
macOS Monterey 12.3.1 Intel Core i9 MacBook Pro(16,1) 2019, 32 GB RAM Pro Tools Studio 2022.4, RME Babyface Pro
Old 04-10-2012, 02:39 PM
Willard Willard is offline
@Zoff +1
I just took this route, except it was for a drive going back into the same computer. I've never had a complaint about CCC, but in doing the clone, I'm usually refreshing with a new OS (which of course you have a thumb drive with the installer on so it takes less than an hour to do and is completely painless!).
But I'm still not without problems ... but that could have nothing to do with CCC.
Pro Tools 9.0.5 | HD3 PCIe | 192 i/o | C|24
Mac Pro5,1 (mid 2010) Westmere 3.33 GHz Hexacore | 16gb ram | OS X 10.7.4 | VEPro 5.3.13141
Pro Tools 9.0.6 | HD3 PCIx | Apogee Rosetta 200 | Magma PE6R4-I
MacPro5,1 (mid 2010) Westmere 3.33 GHz Hexacore |16gb ram | OS X 10.7.4 | VEPro 5.3.13141
Upgrading from G5 to Newer MacPro..... drBill Pro Tools TDM Systems (Mac) 7 05-25-2010 01:57 PM
Carbon Copy Cloner (or sim) copy Disk Authorisations? Jon_Atkinson Pro Tools TDM Systems (Mac) 8 10-07-2009 08:11 PM
Question about Carbon Copy Cloner Shanegrla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 08-27-2009 09:50 AM
Is Carbon Copy Cloner the answer? jlcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-15-2004 10:55 AM
Carbon Copy Cloner joepopp Pro Tools TDM Systems (Mac) 17 12-08-2003 11:25 AM
