Old 03-16-2012, 04:19 AM
protoolsuserman protoolsuserman is offline
Default HD Native Firmware updater issue
Please sort this issue out. Anyone who purchases Pro tools 10 HD will need to downgrade to an older version of pro tools (9.04/05) just to update the firmware on their hd native card.
This is truly a very boring, inconvenient and mind numbing experience that takes up valuable studio studio. I'm a musician, not a computer expert.
I have 2 hd native systems, this being my second one, and I can remember just under a year ago having the same issue which tells me this issue has not yet been fixed. Please sort it out.
Thank you
Avid customer
Old 03-16-2012, 05:01 AM
Default Re: HD Native Firmware updater issue
This issue has been solved a long time ago. See this: http://avid.custkb.com/avid/app/self...p?DocId=429831
It shows you how to use the Native Card Flasher given certain constraints listed. You don't have to downgrade to PT9; PT9 is the minimum to use the flasher so an install of PT10 will be okay.
Jack
QAPLA!
Old 03-16-2012, 05:47 AM
I used this and it doesn't work, I get an error message saying it failed to update..
Old 03-16-2012, 05:50 AM
Is my card faulty?
Old 03-16-2012, 06:10 AM
The error message says (in terminal)
error encountered
DAE error -1166 was encountered
Any ideas?
Old 03-16-2012, 06:11 AM
You may have bricked it; did you allow the process to fully go through? Premature termination will screw up things.
Jack
QAPLA!
Old 03-16-2012, 10:14 AM
RyanC RyanC is offline
This is how mine got bricked! If you are getting the 6 flashes on the back LED and no front LED I think it's ready for mortar...
Does the card show up at all in system profiler?
AVID: LETS HAVE AN EXERCISE IN COMMON SENSE HERE.
Firmware flashers should ALWAYS ALWAYS ALWAYS verify the MAIN firmware BEFORE wiping out the SAFE!!! ALWAYS.
Right now I'm waiting on an email that costs $80, apparently Avid tech support is worth roughly $2000/hr, and even at that don't expect a quick response.
Old 03-16-2012, 10:16 AM
I allowed mine to go through, it counted to %100 4 times and then threw the error code -1166.
Old 03-16-2012, 10:41 AM
I fixed it guys!
Here's what you have to do.
Basically if you get the kernel panics with pro tools hd 9+, you must install pro tools 10 with 10.6.8 installed, then You roll back to 10.6.3 after which when I launched pro tools 10 it updated the car'd firmware no problem.
Then install 10.6.8 again, then install the pro tools HD 10.1 updater.
Hope this helps
Rob
Old 03-16-2012, 12:22 PM
Originally Posted by protoolsuserman View Post
I fixed it guys!
Hope this helps
Rob
The card flasher was supposed to do away with this dance. With the flasher, according to the instructions provided on the page I linked to, you don't even need PT installed, just the HD Native card drivers. I think something else may have happened and you just found a way to get your straightened out that shouldn't have to be done. At least you got it working.
Jack
QAPLA!
(-1166) Firmware issue Mac Pro / Native PCIe fullfluxstudios Pro Tools HDX & HD Native Systems (Mac) 13 05-26-2014 06:35 AM
firmware updater srsoundlab 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-03-2008 01:45 PM
firmware updater boostedrsx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-08-2006 10:47 PM
FIRMWARE UPDATER 1,20R 120359 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-23-2004 01:23 PM
Command|8 Firmware 02.01.01 & Firmware Updater 1.4 Avid General 0 06-08-2004 03:48 PM
