Old 02-26-2012, 05:27 AM
klyg klyg is offline
Default v control (v2) plugin encoder cannot instantiate plugin screen in PT10.0.1
Hi when i use v-control (v2) encoder to instantiate a plugin in PT10.0.1, in OSX Lion, there's no plugin screen that appears in PT10.0.1
previous version 10.0.0 did not have this problem
I tried to reinstall the update (10.0.1) and it sometimes solves the problem
but imediatly after using PT 10.0.1, the problem reappears !
Tried also repair the disk permission, still same problem.
don't know what to do,
Please Help !
OSX lion
MC control+mix = last drivers
PS: No problem with i7 PC PT10.0.1
Cheers !
Old 02-29-2012, 10:44 PM
Question Re: v control (v2) plugin encoder cannot instantiate plugin screen in PT10.0.1
After AVID's suggestions (cf links) that work but need to be repeated everytime i re-open PT,
I just discover an interesting point:
whithin an PT session opened,
in eucontrol setting,
when changing the order of my surfaces,(I used to have MC control first, then MC mix, so changing the order do it)
then the plugins instantiation screens on my mbp works !
Really odd, but works !
PS: I checked my network config, my MBP and all my artitsts controllers are hard networked (rj45) in the same router (Airport Extreme, acting as my WIFI router too), and the AE is hard networked (rj45) to my ADSL.
Any suggestion ?
Best R.
Cheers !
Old 02-29-2012, 10:50 PM
Thumbs up Re: v control (v2) plugin encoder cannot instantiate plugin screen in PT10.0.1
just want to mention that in LOGIC 9 everything is smooth. Plugins instantiation through artists control and mix is great !
Cheers !
2.6.1 Rotary Encoder Issues, and MC Control Touch Screen Freeze anotherchrisperry Artist Series 12 05-04-2012 01:45 AM
no plugin screen that appears in PT10.0.1 OSX Lion with MC control v2 encoder klyg macOS 2 02-29-2012 10:51 PM
plugin screen cut off? tonejunkee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-19-2011 01:35 PM
More Than 1 Plugin On screen? studioslave77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-21-2007 06:32 AM
More than one plugin on screen? JonnyGinese 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-10-2005 02:57 AM
