Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 09-29-2011, 12:15 PM
Raoul23 Raoul23 is offline
Default Midi from drums through command 8 then superior drummer
Hi Guys
just a little help is needed ive always used a midi uno for my digital drums midi info to travel to superior drummer in pro tools. never had a problem. Had to give the midi uno back to the chap i borrowed it off so i thought i use the midi ports on the back of my command 8. Can anyone out there help me set this up as im having no luck what so ever. Plus for some reason i cant get my command 8 to work with pro tools
Thanks guys
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 09-29-2011, 02:14 PM
Default Re: Midi from drums through command 8 then superior drummer
Is the Command8 working as a controller? Did you install the drivers for it(including midi drivers)? Are the ports available in the Midi Studio setup page? that page is the first place to look as you should setup your midi device(whatever you use the trigger).
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 09-29-2011, 02:27 PM
Hi Albee I installed the driver software from the digi site but I didn't see any thing about midi installer. What is the procedure for the midi setup. It was so easy with the midi uno, seems strange it's so much of a faf to get sorted
Regards
Raoul Crane
Old 09-29-2011, 05:15 PM
Regards
Not sure as I don't have the Command 8. Did you look in the midi studio setup and see if the Command 8 midi ports are available? If they are, set them as the ports to use and test it.
New Toontrack video about using E-Drums with Superior Drummer nst7 The Drum Room 0 11-20-2013 07:29 AM
Best way to use VI Drums eg SSD4, Superior Drummer Raoul23 The Drum Room 13 08-17-2012 10:04 PM
Superior drummer or Steven slate drums Raoul23 The Drum Room 20 01-27-2012 03:06 AM
mapping superior drummer to drums spidey01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-02-2008 09:10 AM
Big [bleep] Drums, or Superior Drummer? Peterjk Virtual Instruments 3 03-03-2006 11:04 PM
