Old 09-21-2011, 06:51 PM
danball danball is offline
Default Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0
You guys are awesome, and I've solved so many problems before by just reading your advice. I hope you can help with this one too!
I have just installed Pro tools 9 as a crossgrade from Pro tools 8 LE. When I click on PT9 to start it, it gets to the point where it says "Video Engine failed to initialise" and then it returns the following error message:
and the program crashes.
I have found a couple of instances of this error message on the DUC, but can't seem to find one which matches my situation.
In addition to the software/hardware setup I've filled in, I have an owc firewire drive connected (formatted the pro tools-friendly way). I also have an externally powered USB hub for my ilok and midi keyboard. I've tried disconnecting that and just putting the ilok straight into the laptop. Still didn't work.
I have thrashed preferences and repaired disk permissions too, also to no avail.
I also decided to try uninstalling and re-installing PT9 BUT the uninstaller crashes too! So I can't even try a fresh install now.
Any help would be greatly appreciated.
Thanks!
Old 09-21-2011, 07:42 PM
Default Re: Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0
oops just noticed you can't see my system, here it is:
MacBook Pro 2.4GHz Core 2 Duo 13
RAM 4GB
OSX 10.6.6
Mbox2
Pro Tools 9.0.5 + latest mbox2 drivers
Old 09-26-2011, 04:49 PM
Thumbs up Re: Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0
SOLVED.
Backed up my stuff and did a full erase and install of the operating system. Installed 9.0.2 just in case it was the version, and am slowly re-introducing peripherals and plug-ins.
All good so far! And now I can sneak a little composition in in work
"floating point exception" in thread "mainthread", at address 0x0 simmo.d.cooper macOS 10 03-09-2013 10:34 PM
"Bus error" in thread "MainThread" at address 0x0 Tronic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 62 12-27-2012 10:21 AM
"Bus error" in thread "MainThread", at address 0x0 polbb macOS 1 10-01-2012 06:50 AM
"Bus error" in thread "MainThread", at address 0x0 mnicoli macOS 2 04-10-2012 07:42 PM
"Bus error" in thread "MainThread", at address 0x0 mnicoli Pro Tools 9 1 03-30-2011 08:08 PM
