Old 09-16-2011, 07:17 AM
Nullfusion Nullfusion is offline
Exclamation Smile Strange problem with audio/midi tracks after copy/duplicate
Hello!
I discovered a strange Problem on Protools LE 9.0.3/9.0.5!!!
independent of session or Computer:
After copying OR duplicating Audiotracks/Miditracks a few times (sometimes after the first, sometimes after more copies) the right end of the track is not on the Grid anymore. --> you can only see this when zooming to maximum!!
Settings are on "Grid", tried it with "Sample" based and "Tick" based too.
I also tried it on another Computer with PT 8 and a PT HD5 and the Problem did NOT appear! Its bad, because you cannot just copy/duplicate right on, you need to check every right edge of your Files manually, because if you just copy on, your sound will change after 3-4 minutes.
I checked it with a Click Audiotrack set perfectly on the Grid and put into a Group, with the Edges perfectly cut. After duplicating about 3-4 minutes you will hear its sound starting to change -> i have put it over a midi beat, which was set correctly "manually" until the end.
This means: your Music will NOT sound the same at the End.
Its very little but i think this is not ok. Its causing phase Problems and other Things because its happening randomly.
Any Ideas??
Thank you very much!! :)
(i use iMac i7, 2,9/12GB with OSX10.6.7 and Protools LE 9.0.5)
Edit/Delete Message
Old 09-16-2011, 04:35 PM
The Weed's Avatar
The Weed The Weed is online now
Default Re: Smile Strange problem with audio/midi tracks after copy/duplicate
This is one of several threads talking about the issue.
Search can be your friend.
Cheers,
Demos: brucehayward dot com
Source-Connect: brucehayward
[IMG] code is Off
Midi Editor Copy/Duplicate Leaves off Notes anackman macOS 2 10-11-2012 09:31 AM
Strange problem with audio/midi tracks after copy/duplicate Nullfusion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-25-2011 07:17 PM
midi copy/duplicate: 7.4 can't grab 1st quantized note glankrudolph 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 12-16-2008 07:33 AM
copy or duplicate midi parts crashes PT MP 7.1/7.3 Fishbone Pro Tools M-Powered (Mac) 2 01-22-2007 11:56 AM
strange intermittent duplicate command problem PeterScherr Pro Tools TDM Systems (Mac) 1 08-30-2005 09:09 AM
