Old 10-10-2010, 11:20 AM
jjboogie jjboogie is offline
Default Muted track unmutes when I hit play with no automation written?
I imported a track for reference into a session and after muting it turns on by itself when I hit play! There is no automation written at all.
Weird! Anyone know what that might be?
Old 10-10-2010, 11:39 AM
juhanni's Avatar
juhanni juhanni is offline
Default Re: Muted track unmutes when I hit play with no automation written?
I have encountered this too. It happens when i have an instance of Kontakt 3 running with multiple midi-channels, but same audio output.
Old 10-11-2010, 06:32 AM
Bump
Old 10-11-2010, 08:42 AM
Make it inactive. That only takes a second longer than hitting the mute button(and it won't over-ride you).
Old 10-11-2010, 08:46 AM
That's what I have been doing in the mean time. Just wondering if there was a setting or something that I accidently engaged that makes the muted tracks unmute on there own when I hit play.
Thanks
Old 10-19-2010, 04:12 AM
nigel smith nigel smith is offline
I'm having the same problem on 8.0.4 LE with a DIG002.
If you hit play first, then click mute, it works.
Otherwise it's as you describe.
I am working with a session from v6.4.1 and 3 of the 7 tracks have this problem. Other tracks mute with no problem.
is it a bug, or is there a setting I'm missing?
Old 10-19-2010, 05:33 AM
Usually, its because of "accidental" automation. If you view MUTE automation on the track, you can see what the setting is and change it, or select the automation mode as OFF. I have seen it here and there, but its never been anything persistent on my system.
Old 09-16-2023, 06:59 PM
Are you running on a legacy old 003 or similar? with Pro Tools 8LE? And now you are posting on a 13 year old thread.
Good you are looking at past threads, but can you follow the DUC rules and stop spamming posts onto multiple threads. Post once per problem and focus on describing the most basic stuff about your setup.
In this case you likely should just delete your posts and create a new thread and describe your setup. Esp. what exact version of Pro Tools you are running so other users here might want to spend time trying to see if they can see this behavior on their setup. If this is really just caused by display set to MIDI or clips... that has to be a bug or maybe corrupt session. Does this happen in multiple sessions? Have you trashed Prefs? tried to see if this happens when you start with a totally empty session?
Old 09-16-2023, 07:00 PM
Duplicate of https://duc.avid.com/showthread.php?t=157508&page=2
extra automation written viaspiaggia Post - Surround - Video 4 06-14-2013 11:28 AM
Automation Being Written on Untouched Track Chief Technician ProControl, Control|24, Command|8 12 06-06-2007 11:34 AM
Drawing crossfades in group unmutes muted tracks applewormy Pro Tools TDM Systems (Mac) 4 10-15-2006 04:36 AM
"No automation could be written.... dkroger ICON & C|24 4 12-19-2005 07:43 AM
Fader movement after automation written Siegfried Meier Pro Tools TDM Systems (Mac) 8 01-27-2005 05:24 PM
