Old 07-20-2010, 05:39 PM
Music 101 Music 101 is offline
Default Time and Date not right
I have a mac OSX 11.4 and I'm running protools 7.1 Le. for some reason when I save a file, the time is always saved on 8:50pm and the dates are always 6/7/2010. I wanted to know if any one can help me correct this problem
Old 07-21-2010, 12:02 PM
davidp158 davidp158 is offline
Default Re: Time and Date not right
Are your times and dates correct for files saved with other applications?
Does the time and date display correctly in the Finder menu bar?
You might try resetting it within the System Preferences; switch to a different time zone, exit, and then go back and reset it to the correct time zone.
If you're experiencing time and date issues, you may need to zap the PRAM. Some of the PRAM data is dependent on the internal battery, which will wear out over time. If your Mac has some years on it, you should probably test the battery and change it if it appears low. Typically, the battery is a 3.6 V, small format and readily available.
cheers, Dave
Old 07-22-2010, 05:09 PM
Thanks Dave do that problem make it hard for the system to find files because now some of my ptf session files cannot be found!
Old 07-22-2010, 05:13 PM
Time and Date shows perfect, so it's not the battery I'll try a reset
Old 07-22-2010, 11:28 PM
Zapping the PRAM may not help relocate session files, but may help fix the date and time problem. Here's a link from Apple regarding how to do this, and what zapping the PRAM effects:
http://support.apple.com/kb/ht1379
Before you zap the PRAM, check to see if other applications are saving files with the correct date and time. If so, the problem may be specific to PTLE. If all apps are saving with the wrong date and time, you have a system issue and need to address that. Regardless, its probably worth doing some basic Mac maintenance (rebuild directory, repair permissions, check hard drives, etc.).
Be sure to review the trouble shooting guidelines from Avid:
http://duc.digidesign.com/showthread.php?t=54888
PTLE tends to be very demanding on host computers, so you have to follow Avid's guidelines and system configurations closely.
BIOS time/date not saved musicman476 VENUE Live Sound Systems 5 06-26-2012 09:39 AM
OT: OSX Loosing Date and time settings audioluche Pro Tools TDM Systems (Mac) 8 10-19-2010 11:42 AM
G5 date and time issue spidey01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-19-2009 09:30 AM
Date&Time keeps going to 1969 in 10.2.4. ? beatboy Pro Tools TDM Systems (Mac) 7 03-29-2003 07:56 PM
Dodgy Mac Date and Time Stu Barbour 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-12-2002 04:55 AM
