Old 07-15-2010, 07:32 PM
linderefter linderefter is offline
Default Hard Panning Issues in PT LE
When I want to make a hard pan left or right, there's an "signal leak" in the opposite channel. I've tried this in 2 different CPU's and 2 different mbox's.
In the mixing screen it appears to be ok, no signal in the opposite channel.
It happens with headphones and monitor out
Heeeelp...this is driving me crazy!!!
Mbox 2 and Mbox mini with PT LE 8.0.3
Old 07-16-2010, 01:30 PM
SKI SKI is offline
Default Re: Hard Panning Issues in PT LE
Then it's probably not there.
It's more than likely coming from your monitoring or headphones.
Try doing a BTD and then listen to that on something to see if the panning is correct.
URBAN MUSIC-
(Hip Hop and R&B)
Old 07-16-2010, 10:50 PM
I'm pretty sure it is not the connection...it is between the software and the mbox. When I plug the headphones directly to the mbox, the same thing happens.
Old 07-17-2010, 12:22 AM
SKI SKI is offline
That really means nothing.
As I suggested before, do a stereo Bounce and play it thru something else besides the mBox.
That will tell you if the panning is there or not.
URBAN MUSIC-
(Hip Hop and R&B)
Old 03-13-2011, 01:20 PM
claycutnut1 claycutnut1 is offline
ok, first id like to say hello to all. I am having a similar issue. i am running pro tools 8 on an imac. I CANT HEAR ANY SOUND WHEN PANNED HARD RIGHT, BUT WHEN I PAN HRD LEFT I HEAR SOUND FROM BOTH LEFT AND RIGHT SPEAKERS. ALSO, I CAN SEE A VIVID RIGHT SIGNAL ON MASTER TRACK, BUT NO SOUND ACCOMODATES THE SIGNAL. i have an avid mbox interface, and the mono button on interface is turned off.
PLEASE SOMEONE HELP ME PLEASE!!!!!! THANX
Old 03-13-2011, 08:31 PM
to claycutnut1 Please post your message once only to the correct forum
Delete this post. and please stop posting the same issue in everyone else's threads
MIDI panning issues mojovoodoo MIDI 2 09-03-2013 06:41 PM
Panning Issues with Pro Tools LE 8 aarborn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-07-2013 04:10 PM
PT9 bug: Hard panning reopening centered tclash macOS 0 06-07-2011 08:15 PM
Panning Issues Jonesies1 Pro Tools 9 6 11-20-2010 07:07 PM
HELP! Hard Panning bleed krop015 Pro Tools TDM Systems (Mac) 3 08-25-2010 12:29 AM
