Old 01-27-2010, 02:18 PM
mix_master_adam mix_master_adam is offline
Default Replacing USB on Eleven Rack with Firewire?
I'm considering putting together a simple mobile rig using a MacbookPro and an Eleven Rack.
The only thing though is I'm actually curious if the USB interface can be replaced with a Firewire port on the Eleven Rack to give a faster transfer speed.
The other idea I am contemplating is purchasing a 003R and having Black Lion do their thing, then using the Eleven Rack in conjunction with the 003R. I'm not looking for additional inputs as 18 is the limit from what I understand, but I want to know if would then be possible to have the Eleven Rack handle its own DSP.
Quite confused.
Thanks!
Old 01-27-2010, 02:59 PM
Default Re: Replacing USB on Eleven Rack with Firewire?
The Eleven Rack handles its own DSP in any configuration. I doubt there is any way to change the USB interface.
Old 01-27-2010, 03:29 PM
CME CME is offline
I would think it would be next to impossible to change from USB to FW. They are totally different protocols. As far as using the 11R and 003 together, it can be done but isn't as graceful as I had hoped it would be. Essentially if you wanna use both at the same time you would route the analog outputs from the 11R into 003. Kinda negating some of the recording features IMO. At least this is my understanding as to how it would have to work. I believe you would still have control over the 11R through USB but no audio would be passing through it.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 01-27-2010, 04:47 PM
sunburst79 sunburst79 is offline
11R handles its own DSP.
It supports all LE sample rates of 44, 48, 88, 96k.
Given the limited amount of tracks its passing down USB connection it should be fine.
FW400 isn't really any faster-its just that it doest require a babysitter.
And no you cant use a FW to USB converter of some type. Ultimately its as slow as the slowest or weakest interface spec.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
Advice on replacing 002 rack soundmind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 05:56 PM
Replacing M-Box 1 for FireWire solution Thomzzzzz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 09-04-2008 05:39 AM
Replacing 002 Rack with MBOX 2 PRO ??? waterbedman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 02-27-2007 05:32 PM
