Old 12-15-2009, 03:41 AM
fivefilms fivefilms is offline
Default RECORD Button Blinks Five Times Before Starting
hi all,
so all of a sudden, as i'm in the middle of recording a part, the "record" and "play" buttons wait five blinks before starting the song. i often do a quick stop-start thing with the apple/space bar combo when i'm recording, and i'm sure i must've hit a shortcut somewhere (as i often do with option/space, which enables the "double-space bar to record" function). can anyone help. please? i've turned my "pre/post roll," "loop playback" and "loop record" off and on in every possible configuration and i've rebooted a bunch. thanks.
losing my mind,
mike
iMac, OSX 10.4.11
2 GHz Intel Core 2 Duo
4 GB 667 MHz DDR2 SDRAM
Pro Tools LE 7.3.1
Old 12-15-2009, 05:34 AM
jrtme jrtme is offline
Default Re: RECORD Button Blinks Five Times Before Starting
Check your buffer size
Old 12-15-2009, 07:07 AM
daeron80 daeron80 is offline
In the transport window with everything showing, is the metronome button lit? That adds a two-bar count-off on record. Pressing the 8 on the number pad (not the one with the * on it) toggles it.
David J. Finnamore
Nyquist was right.
PT 2021.6 Ultimate | Omni | macOS Catalina in a Trashcan 32GB
PT 2021.6 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 12-16-2009, 01:38 AM
daeron80, the 8 fixed it. thanks so much.
Red Record light blinks/auto read goes to black DanielZ macOS 3 05-29-2012 05:45 PM
Record 1 audio track, then go to record a second, the timer button flashes... help tdubthatsme General Discussion 5 02-27-2011 05:39 PM
MBox 2 USB not recognized, blinks 3 times on loop TimKem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-14-2010 03:32 AM
Play button flashes before starting jonathans9 Pro Tools TDM Systems (Mac) 5 04-19-2008 03:09 PM
BTD 12 times with one button clarpark Pro Tools TDM Systems (Mac) 1 11-15-2000 12:57 PM
