Old 05-22-2009, 10:15 AM
spreston spreston is offline
Default Upgrade question - can I use mbox2 micro upgrade on 002 system?
I have PT LE 7.4 running and would like to upgrade to version 8.x I received a free upgrade when I recently purchased the mbox2 micro. Can I run the free upgrade on my 002/computer or do I need to purchase another upgrade to 8 for that system?
Thanks in advance.
Old 05-22-2009, 10:23 AM
sw rec sw rec is online now
Default Re: Upgrade question - can I use mbox2 micro upgrade on 002 system?
As far as I know, it's perfectly legal for you to use the upgrade on YOUR stuff but NOT to distribute it. Logistically you can do it. Digi?
Old 05-22-2009, 11:22 AM
MikeX MikeX is offline
I've done the same thing. I have PT 8 running on two separate PC's with the identical list of plugins on each... one is my mobile recording laptop and the other one is my mixing desktop. I also switch between a 003 and Mbox2 between them...
So yes.
Pro tools HD 9 - HD3 setup w/96 IO
AMD 3.81GHZ Phenom II X6 CPU - 8GB Ram - Win7 64-bit
Focusrite Voicemaster Pro
Presonus StudioLive 16 Channel Mixer
Digimax D8 8-Channel Preamp
Command 8
Vocal and Instrument Recording/Live PTHD Mixing
Mbox2 Pro & Mbox2 Micro on the same system Freakazoid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-16-2011 01:38 AM
Installing PT L.E. 6.8.1 and MBox2 on new Windows 7 system - 8.0.5 upgrade? Badfish00 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-18-2011 02:49 PM
New MBox2/PTLE 7.3.1 user - 7.4 upgrade question SteveC7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-24-2011 11:59 AM
MBOX2 Pro Buying Used/Upgrade Question. malibuproducer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-29-2009 12:58 PM
new system/upgrade question OneMadSon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-24-2007 05:53 PM
