Old 05-22-2009, 01:11 AM
kydicarus kydicarus is offline
Default Audio from Venue coming into PT over HDx is about -20 db
hey guys,
ive been doing some some live recording with the venue using hdx into an HD2 Accel rig running PT 7.4.2. The levels getting tracked into PT are way less than what's hitting the board. What am i missing? Thanks a lot.
Old 05-22-2009, 03:04 AM
emluper emluper is offline
Default Re: Audio from Venue coming into PT over HDx is about -20 db
The systems reference 0 dB differently. Quickest fix is to change your meters from peak to RMS. That will get you more signal to PT. Easiest way to understand what is going on is to watch the 05/23/08 webinar on PT HD vs PT LE and the 06/25/08 webinar on Virtual Soundcheck.
http://www.digidesign.com/index.cfm?...4&itemid=31029
Old 05-22-2009, 07:59 AM
Justin Bartlett Justin Bartlett is offline
Originally Posted by kydicarus View Post
hey guys,
Your levels are the same. 0dB on Venue equals -20dB in Pro Tools.
Old 05-22-2009, 09:06 AM
That is correct electrically. I should have said that 0dB on the meters is referenced differently, PT references 0dB as 0dBfs while on the Venue 0 dB will equal -18 to -20dB in PT. Thus you will always be -18 to -20 dB down in PT if your Venue meters are set for Peak. Optimum input for PT should come in between -12 to -8 dB and the easiest way to get that gain back is to switch to RMS metering.
HELP!NO AUDIO coming out of PT HD 10.2 HELP! CDac Pro Tools 10 1 06-25-2012 10:18 PM
New webinar: Meet the VENUE SC48 Remote System, Stage 48, and VENUE 3 bobcats VENUE Live Sound Systems 2 03-24-2012 08:35 AM
Sync video w/ audio rec w/ Venue HD blakesaw VENUE Live Sound Systems 4 10-28-2010 12:08 AM
Audio not coming through on new PC set-up ajp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-14-2006 05:44 PM
No Audio Coming In From Mic ...help Tammaru Digidesign Hardware & Software 0 03-06-2001 09:20 PM
