Old 05-21-2009, 01:05 PM
Roland Clarke Roland Clarke is offline
Default Higher channel count on Mixrack
I saw a little bit about the new 2.81 software on the Webinar a few moments ago and it brings to mind one question. Will the addition of the 24 extra channels to the D show 2.81 software allow for returns of selected channels from 1-48 from a connected HD2 Protools system? Thanks in advance.
Regards
Roland
Old 05-21-2009, 01:29 PM
emluper emluper is offline
Default Re: Higher channel count on Mixrack
It's probably a question for Robert Scovill or Sheldon, but knowing how most of the console line works I would say if you're using the HDx Assignable inputs into the extra sixteen processing inputs you should be okay.
Old 05-21-2009, 02:36 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Hi Roland,
The additional sixteen input channels (no 64, up from 48), can be patched to any input source, including any of the sixteen HDx assignable inputs. HDx inputs 1-48 are always hard-wired to replace Stage inputs 1-48, and can't be individually selected.
Sheldon
Old 05-22-2009, 01:44 AM
Hi emluper, I should have stated in the first message that it was a question for Sheldon or Robert, my bad.
Thanks for the reply Sheldon, I can think of a couple of places where this will be really useful, particularly if using the system for a rehearsal room tracking session (I'm thinking monitor feed stems, etc).
Regards
Roland
SATA or Firewire 800 for higher track count? BigEvil Pro Tools TDM Systems (Mac) 7 01-17-2011 02:39 AM
Higher simultaneous recording track count in 7.3 coronos Pro Tools M-Powered (Win) 1 12-14-2008 01:09 PM
Trackball response slows down with higher track count QuickPuppy ICON & C|24 0 08-02-2007 02:34 PM
G4 supports higher voice count than G5 at 192? DrDVD Pro Tools TDM Systems (Mac) 5 02-19-2005 01:09 PM
Higher Track count for ProTools Le??? NuBus General Discussion 7 07-21-2001 12:48 PM
