Old 05-07-2009, 06:34 PM
djca djca is offline
Default Help with opening a blank session
when i open a session tamplate, it works fine but when i try to open a blank session, it askes to give it a name then press save. but a massage always pops up that says "session must be on audio record volume. if permitted, set the volumes in question to R "record" in the workspace.
but i cant find that option.
thanks for any help.
Old 05-08-2009, 12:37 AM
TOM@METRO's Avatar
Default Re: Help with opening a blank session
What version of Pro Tools are you running?
How are your drives formatted?
What O/S are you using?
Are you using a qualified separate audio drive?
http://duc.digidesign.com/showthread.php?t=193637
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2021 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 05-08-2009, 02:58 AM
danander11 danander11 is offline
Try this...
Start PT.
Select WINDOWS from the menu bar.
Select WORKSPACE from the list it gives.
A window will pop up with your drives on it. Your operating drive should be C.. You should also have at least one more drive there.
In the first column to the right of the drive name will be a column with either an R, P, or T in it, (Record, Playback, & Transfer). Set your SECOND drive, (or whichever drive you are using), to R for record. PT does not like to record to the operating drive.
All of this is in the reference manual, and in much greater detail, starting on page 260.
Close out and you should be alright.
Blessings!
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Counter display blank when opening session Armando ICON & C|24 2 03-06-2013 03:17 PM
Blank Session settings skiffle Tips & Tricks 2 11-27-2012 07:19 AM
Possible To Open a Blank Session? KenRyan Pro Tools SE and Essential (Win) 0 09-20-2011 07:58 AM
Session File Blank Chombo Pro Tools M-Powered (Win) 1 08-31-2009 09:42 AM
session is blank with none of the tracks onecrackedmind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-07-2004 11:15 PM
