Old 02-27-2009, 04:25 PM
chanlon25 chanlon25 is offline
Default PT 8 with Avid Fibre Mgr 5.1 WILL NOT Open let me open Sessions!
HI - I recently updated from Pro Tools 7.4.2 to Pro Tools 8.0 (cs2) and whenever I open an old 7.4.2 session with Avid Fibre Manager 5.1 open, PT crashes. I can open a new session in PT 8 - but as soon as I import an OMF off of our Unity drives, PT will crash (assertion error / altura ports).
Any idea what's going on?
OSX 10.5.6 / G5 2x2.5 / Avid Unity 5.1 / Fibre Manager 5.1
Old 03-02-2009, 09:46 AM
Default Re: PT 8 with Avid Fibre Mgr 5.1 WILL NOT Open let me open Sessions!
To elaborate further - here are my specs:
G5 2 x 2.7
Mac OSX.5.6
PT 8.0cs2
Digi 192 - latest firmware
Sync I/O - latest firmware
Avid Unity Media Network FibreManager 5.1.2 (430)
ATTO Celerity FC-42XS (PCI X)
All my cards are in the slots approved by Avid. The issue becomes whenever I try to pull audio/ video from the drive (whether opening a session with an previously imported OMF or trying to import an OMF) I get the following error:
Could not complete the Open Session... comman because Assertion in "/Volumes/Development/vb_protools_8.0_cpr_2/AturaPorts/Fic/MacBuild/.../Source/DiskScheduler/Volume/CDiskVolumeMacOS9.cpp", line 214.
In some cases, when I bring an OMF, PT immediately crashes.
This exact same set up worked fine with ProTools 7.4.2 c2 in the same push/pull scenario. Digi - any idea what's different with PT 8 to get this error?
In the meantime, I'll have to downgrade to 7.4.2cs2 to continue working with Avid Unity.
Old 03-02-2009, 11:08 AM
One other note: whenever I mount or unmount drives on Unity using Fibre Manager, I get the above error. This conflict seems project independent, since I have PTHD 8 open when mounting/ unmounting drives, but have no projects open.
Old 03-03-2009, 09:41 AM
DigiTechSupt's Avatar
I don't have the specifics handy at the moment about what, exactly, is causing the issue, but I do know that we've logged it and a fix is being worked on. I'll try to get an estimated date for release of a fix, but can't guarantee that I'll be able to or even that it will be accurate, since several issues are usually rolled into any particular CS release.
Avid Audio Tech Support
Support FAQ
Old 03-03-2009, 10:11 AM
Thank you so much for looking into this; we'll keep an eye out for the next CS to see if there's a fix. In the meantime, we'll keep on 7.4.2.
Thanks!
HTML code is On
Cannot open PT9 Session in PT10 - ""could not complete the open sessions command..." median Pro Tools 10 5 10-01-2013 11:14 AM
DTS: Will the new more open avid open up Eucon? RyanC Artist Series 2 01-13-2012 10:31 AM
sessions always open with mix window track list open jaglance Pro Tools TDM Systems (Mac) 2 08-03-2009 06:03 PM
Help! Need to open PT 5.xLE sessions in PT 8LE JuanFerVal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-05-2009 09:27 AM
Will 6.4 open 6.7 sessions Cawbaby Pro Tools TDM Systems (Mac) 1 12-31-2004 03:10 AM
