Use of Suspend Automation
Hi everyone...
Can someone clarify me the use of suspend automation in Protools. I in particular was not able to know the use of it... So hoping someone will help me out... Thanks in advance Ramu |
Re: Use of Suspend Automation
I use it a lot...
Maybe you just want to try something out without committing it to your automation (alt takes,mutes, etc.) Maybe you want to copy something in it's original form without the automation. Maybe you just want automation to not play for one reason or another. You could do the same thing by turning the automation off with an option-click, but suspend is a little easier, especially if you have a control surface where it appears as a button. Bob
Save early and often! (or once a day whether you need to or not...) |
Automation suspend I use a lot for VO recording when doing rev's to a mix. So I don't blast the Talent I just turn off automation then I can just temp drop the audio bed while tracking VO talent.
Also used a lot when auditioning new eq setting for a different angle / scene of a film. cheers Kevin |
The 003 console's support for automation control is excellent...The major reason I still have the 003 for mixing (whilst having moved over to the 2626 for tracking). |
Thanks Friends,
But is there any special use of "suspend automation" instead of "turning off the automation". |
win7 suspend automation bug 10.3.7 | studiosus | Windows | 10 | 07-17-2014 03:44 PM |
Suspend Trim automation | Bart HLH | Pro Tools TDM Systems (Mac) | 1 | 11-16-2012 04:15 PM |
How to setup Quickeys to Suspend Automation | danijel | Post - Surround - Video | 15 | 10-21-2011 04:27 AM |
Shortcut/keystroke for automation suspend? | Floydio | Pro Tools TDM Systems (Mac) | 0 | 09-09-2008 03:24 PM |
Suspend Automation Playback for some but not all | Don Geppert | Pro Tools TDM Systems (Mac) | 3 | 02-16-2006 04:31 PM |
