Old 02-13-2009, 05:27 AM
Chris King Chris King is offline
Default Opening a Pro Tools file
When I finish working on one song and try to open another, PT hangs in various places whilst loading. It is not a plugin because it always loads up after the computer is restarted perfectly.
The problem is moving from song to song which I need to do.
Another thing is that I seem to need to quit PT before moving to a new song rather than just close that song. If I do, it quickly tells me that the RAM is struggling.
Advice would be appreciated.
Thanks
Chris King
Old 02-13-2009, 08:04 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Opening a Pro Tools file
Thanks
Hi Chris its Chris here
Are you on PT8? if so you could try turning off "use DSP cache" which is on the system usage meter! there's a small pull down arrow menu and make sure its un-ticked.
What you say ram is struggling! what error message do you get? whats the exact wording?
We'll need more information about your system, what computer and OS and all specs and which version of PT and any other peripherals connected to your system!
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-13-2009, 10:16 AM
Thanks!
PT8
HD3
MacPro 8 core
6 gig ram
3.2 Ghz
10.5.6
I can't make it do it now - perhaps its OK.
Chris King
Opening or transferring a wav file into a new Pro Tools Session Lou21 macOS 6 02-19-2013 02:58 PM
Problem opening pro tools file. CottersJ Windows 1 04-02-2012 01:50 PM
Pro tools 8 LE file not opening in m-powered sarangetti Pro Tools M-Powered (Win) 1 07-26-2011 03:44 PM
Opening a .PTS file with pro tools LE 7.3.1 Zachmac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-01-2007 06:54 AM
Opening and OMF file ? Notefarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-26-2003 01:58 AM
