Old 01-26-2009, 03:34 PM
spinsah spinsah is offline
Default Keyboard shortcut for selecting next / previous track in Mix window?
Hey everyone,
I'm trying to figure out a way to use the keyboard to select next or previous track when in the MIX window. I know that in the edit window when you have keyboard focus mode on, you can use the 'P' and ';' keys to go up and down from track to track, but does anyone know if there is an equivalent way to do this from track to track in the mix window?
I have multiple instrument tracks with a different MIDI instrument on each. To switch between them it would be so much handier to be able to use the keyboard instead of having to point & click each track name with the mouse every time.
Any input would be appreciated, thanks!
Old 01-26-2009, 06:06 PM
chris7419 chris7419 is offline
Default Re: Keyboard shortcut for selecting next / previous track in Mix window?
There isn't one. You'd think it would be a given wouldn't you?
Here's the workaround -at the top of the Edit Window, highlight the Link Track and Edit Selection Button. This makes it so that when you create a selection on audio or midi on a track, the track itself becomes selected.
So far your hand's still on the mouse, so to move the selection you made on a track up or down, thus selecting the track (or very usefullly GROUPS of tracks), you make sure A-Z mode is on and use the "P" and ":" (colon) keys.
As long as you have a region selected, or you have manually made a selection, then you can use this method to zip up and down tracks.
Old 01-26-2009, 07:33 PM
brianstoner brianstoner is offline
The key command for that is
While holding the control key use the "P" and ":" (colon) keys
Hope that helps
b
Old 01-28-2009, 12:37 PM
That WORKS thank you so much!!!
Can't believe I was unable to discover such an easy shortcut myself too LOL - it's not like it was one of those Control-Command-Option-Shift-Jump-Spin-Touch Toes type of hidden shortcuts :)
PT 10 | shortcut for selecting next/previous clip johannes1 Tips & Tricks 2 10-17-2013 03:34 AM
Next/previous playlist keyboard shortcut matthias.matthias Pro Tools 10 0 07-18-2012 03:28 AM
Keyboard Shortcut Request: Snap to Previous / Next neotone1 Pro Tools 9 1 12-02-2010 08:07 AM
Keyboard shortcut for selecting playlists kevinb511 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-30-2007 03:26 AM
keyboard shortcut for next/previous marker ? rexdiver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-10-2004 09:59 AM
