Old 12-25-2008, 12:22 PM
cpoulos13 cpoulos13 is offline
Default need help with transfuser
How do you sync up transfuser to start playing when you hit record in pro tools? Thanks.
setup: Mac OSX 10.5.4, pro tools LE 7.3, transfuser
Old 12-26-2008, 01:05 AM
Default Re: need help with transfuser
bump...
Old 12-26-2008, 06:44 AM
Technog0d Technog0d is offline
I usually do one of two things... I either copy the midi from the transfuser track or record a 2 or 4 bar loop and drag that to a track. If you want to add dynamic effects with beat cutter, then i would drag the midi patter by selecting the sequencer piano key and dragging it on to the instrument track and then tweak your effects as needed. I am not sure about just syncing the start as i have never done that. I think it may be able to be done in the same way by just choosing the pattern you want by selecting the pattern note and then just tell it when you want the pattern change in the sequencer.
Old 12-26-2008, 06:13 PM
thanks
Transfuser Tip DonaldM Virtual Instruments 9 04-28-2014 11:05 AM
transfuser x 2 mafiacondon Virtual Instruments 10 03-05-2010 03:17 PM
installing Transfuser full on Transfuser trial wfasano Virtual Instruments 2 06-30-2009 04:14 AM
Transfuser V1.5? Mason00 Virtual Instruments 2 04-09-2009 08:49 AM
transfuser/ geeball Virtual Instruments 0 02-08-2009 10:05 PM
