Old 05-26-2008, 07:26 PM
kavs kavs is offline
Default Mbox2 audio / midi not showing in windows control panel
I am having problems getting the mbox to work for my windows audio and midi.
I am not using pro-tools so i have installed the Standalone Digidesign Windows Audio Drivers.
I have updated the firmware.
The ASIO drivers are working fine, so the problem seems to be with WaveDriver.
When i got to control panel > sounds & audio settings, the option is not there for either Audio or Midi.
I have disabled my computers internal soundcard in case of a contflict.
I have checked and MMERefresh.exe is running at startup.
The only thing that i can see that has a problem is when i go to mbox midi driver in the device manager, then:
properties > properties (tab), select midi driver > properties (button)
There is a message:
"Status: Driver enabled but not functioning properly"
I've checked the audio driver in the device manager and it is fine.
Any help would be greatly appreciated, im getting seriously frustrated trying to sort this problem out.
Thanks,
K.
Mbox2 Mini ongoing problem - NO control panel Adwel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 04-11-2012 12:59 PM
Mbox2 MINI control panel not showing up Adwel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-26-2011 06:34 AM
Mbox2 control panel jjuhkam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-09-2011 08:03 AM
002 Rack not showing as option in windows control panel (sound settings) TheRealJayP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-08-2009 04:14 PM
sound control panel/audio input? anders Tips & Tricks 1 07-13-2000 09:28 PM
