Old 05-04-2008, 05:36 PM
bwandon bwandon is offline
Default Edit pitch bend midi data
Does anyone know how to edit the midi data from my keyboards pith bend wheel? I know how to do it in reason, but Im not sure if pro tools will let me.
Old 05-04-2008, 06:05 PM
musicalavtech musicalavtech is offline
Default Re: Edit pitch bend midi data
I reckon you recorded the pitch bend data to a midi or instrument track. On the edit screen, look under the track name where it says 'notes' by default. Clicking on that pops up a mini-screen where you can scroll down to select pitch bend. You should then see data that you recorded. Select what you need to edit and then use the trimmer tool or smart tool to change the data. Refer to pg 221 and 427 of the PT reference guide.
OSX10.6.8, 1st gen Power Mac,
PT8.0.5, Mbox2
Old 03-24-2018, 08:20 PM
DumbIT DumbIT is offline
March 2018
Wow - this is an old thread, but Xpand hasn't changed since 2008 ...
Leave the keyboard alone (+2/-2 semitones).
Select your instrument in the XPAND panel.
To the right of the PAN FX1 FX2 knobs is a panel with TR/FINE, HI/LO KEY, VOICE MODE, and PB Range.
XPAND defaults the PB Range (pitchBend) to TWO semitones, but the pull down list goes 0-12!
Took me an hour to figure this out after looking at other products. DOH!!!!
Change pitch wheel bend range in Midi event operations phair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-24-2018 08:21 PM
Pro Tools LE 8 Midi Pitch Bend Problem W Sound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-09-2011 02:09 PM
MIDI track not reading pitch bend data? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-11-2009 07:04 PM
MIDI Pitch bend question, please? William 2014 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-30-2006 11:53 AM
MIDI : Pitch Bend Muxlow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-01-2003 09:28 PM
