Old 04-10-2008, 06:02 PM
alfadog alfadog is offline
Default Run Time Error When Using Sound Replacer
I'm getting a run time error anytime I use "Sound Replacer". The plug-in loads up, but then when I attempt to import an audio file into one of the 3 zones I immediately get a run time error and Pro Tools crashes. I've dumped the databases, have the latest 7.4 upgrade, and the latest Music Production toolkit upgrades. Any ideas on what can be causing this? Everything else seems to be running fine.
Old 04-15-2008, 01:03 AM
ace621 ace621 is offline
Default Re: Run Time Error When Using Sound Replacer
same thing happened to me..
if you're using 7.4cs2, and vista (i'm using home premium) this might be the cause:
32-bit samples.
change 'em to 24-bit or 16-bit.
Avid Driver Replacer requires Reboot Each time! Gary Bouchard FireWire & USB Audio Interfaces (Win) 16 06-25-2013 09:20 AM
Sound Replacer & DAE Error 7401 Audio85 Virtual Instruments 0 06-29-2010 10:24 AM
Is there a drum replacer/sound replacer??? sethbrand General Discussion 2 03-08-2006 08:40 AM
my sound replacer makes the samples sound higher joeldavidlauver Pro Tools TDM Systems (Mac) 2 05-24-2005 07:59 AM
Sound Replacer Alters Sound of Sample. vze24x2x Pro Tools TDM Systems (Mac) 0 10-25-2003 07:10 PM
