Old 06-19-2001, 10:30 PM
Brimmy Brimmy is offline
Default Unable to Open
I have recently upgraded fom PT 5.0.1 to 5.1.The system is a PTMIX system running on a Mac G4.Since the upgade I have had a number of problems opening sessions from the older version. This however is not consistent and some sessions open sometimes but not others.When trying to load a 5.0.1 session everything appears to be OK -the session boots up the DAE,locates and appears to load the audio files,the Pro tools menus appear at the top of the screen,then it suddenly crashes.When I check to see which programmes are still running ,the DAE is there but not Pro Tools.When I try to restart however I am told that the DAE is still being used.The session I really need(and have not been able to open at all) to be able to open is quite large(1.5gig) and I have tried copying it onto different drives but this has not solved the problem.Individual audio files from the session can be imported into 5.1 sessions but I really need to open the whole session.Any ideas please?
joseph
Old 06-20-2001, 05:40 AM
DigiTechSupt's Avatar
Default Re: Unable to Open
-It appears as if the session is corrupt. Use the File>Import Tracks feature in PT 5.1 to move the data into a new session file and see if you can get it to open.
Brent
Avid Audio Tech Support
Support FAQ
Still unable to open with PT 11.1 jeanfdem Windows 1 01-22-2014 05:47 AM
Unable to open Sessions (Tracks unable to load) palmify91 Pro Tools 10 1 03-27-2013 08:00 AM
PT 9.0.5 with Lion - unable to open other MIDI apps open as standalone Rebel macOS 29 05-22-2012 10:49 AM
Unable to open Pro Tools! Jed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-30-2007 05:32 PM
unable to open after 5.1.1 update redarrow32 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-11-2001 08:27 AM
