Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 01-18-2001, 08:41 PM
Shan Plourde Shan Plourde is offline
Default How do I record bass/drums through MIDI into Protools?????!??!?
Ok, I'm sure this is possible...
How the hell do you setup a drum MIDI track, record your drums to it, setup a bass MIDI track, record your bass to it, and have your MIDI sound module play the right sound banks? Jesus, this is more work than I thought it would be! Guess I gotta suck it in, that's the way it goes!
THanks,
Shan Plourde
Old 01-19-2001, 06:55 AM
Rams Boy Rams Boy is offline
Default Re: How do I record bass/drums through MIDI into Protools?????!??!?
Add a MIDI track just as if you were adding an audio track. Then on the mix window, on that MIDI track assign your keyboard of choice (the same way you would assign what input on an audio track).
Old 01-20-2001, 12:46 AM
lwilliam lwilliam is offline
You will need midi triggers on your drum set as well as a module that can accept the trigger input (such as an Alesis DM5 or DMPro), and a pitch-to-midi converter for your bass (if they're anything like the guitar controllers, better be prepared to clean up your playing).
Otherwise, use a midi keyboard controller.
LW
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Midi Drums and bass (Xpand2) lose sync-aye carumba scrnplyr macOS 4 04-02-2012 11:32 AM
Using MIDI to record drums HELP rjv0807 Pro Tools 10 4 12-13-2011 12:14 PM
MIDI DRUMS/BASS. how to eq, reverb, delay etc. MUKULIA DESIGN Pro Tools SE and Essential (Win) 6 02-22-2010 02:15 PM
Syncronizing Midi Bass & Stereo Drums? dts.music Tips & Tricks 1 01-27-2007 09:43 PM
Want to record guitars, bass, drums, vox - is Digi 001 for me? xnorfin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-01-2001 04:49 AM
