Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 03-11-2007, 07:28 PM
boboc2 boboc2 is offline
Default Cannot change drive to audio volume even after formatting
i have an iMac OS X 10.4.6 1.83 GHz Intel-mac, m-audio fastr track pro interface, and a lacie 250 firewire external hard drive. I have tried to reformat my drive many times now, and every time i try to change the record volume, it will not allow me to select "playback" or "record".
I used my hard drive on different pro tool set ups, and it worked just fine from the start. I know that my version of pro tools is compatable with the lacie hard drive because I've used it before. I feel like i have tried it all.
if anyone could offer any advice, i would really appreciate it.
thanks,
Old 03-12-2007, 09:42 AM
zgwonth zgwonth is offline
Default Re: Cannot change drive to audio volume even after formatting
Could be a permissions problem, so check to make sure those are set correctly.
Sometimes this happens to me, but I find that if I restart Pro Tools and power cycle the drive I'm OK.
Good luck.
Old 03-12-2007, 10:38 AM
DigiTechSupt's Avatar
Have you tried trashing preference or database files yet?
How is the drive formatted, exactly?
Avid Audio Tech Support
Support FAQ
Old 03-19-2007, 01:54 PM
This is the info from the drive:
Type : Volume
Disk Identifier : disk2s10
Mount Point : /Volumes/LacieHD ProTools
File System : Mac OS Extended (Journaled)
Connection Bus : FireWire
Partition Type : Apple_HFS
Device Tree : /PCI0@0/PCIB@1E/FRWR@3/node@d04b6802054692/sbp-2@c000/@0:10
Writable : Yes
Universal Unique Identifier : 297C8EC3-33DC-3E97-9242-E6CABC72C4EE
Capacity : 232.8 GB (249,924,190,208 Bytes)
Free Space : 232.4 GB (249,585,090,560 Bytes)
Used : 303.3 MB (318,078,976 Bytes)
Number of Files : 38
Number of Folders : 13
Owners Enabled : No
Can Turn Owners Off : Yes
Can Be Formatted : Yes
Bootable : Yes
Supports Journaling : Yes
Journaled : Yes
S.M.A.R.T. Status : Not Supported
Disk Number : 2
Partition Number : 10
It's formatted as Apple_HFS. I used the Volume format: Mac OS Extended (Journaled) when I Formatted the hard drive. I don't know what else I can do. I had a few friends who are experienced with ProTools look at it also and they are baffled as well. Do you have any other advice?
thanks,
Old 03-19-2007, 01:55 PM
And yes I tried trashing the database files but not the preferences yet. how do i do that?
-thanks,
Old 03-19-2007, 02:54 PM
Info on trashing prefs can be found in the OS X Setup and General Troubleshooting sticky at the top of this forum.
What version of Pro Tools are you running? If it's not 7.1.1 or higher, that could be the problem...
Support FAQ
Formatting an audio drive in a new imac g5 cyrus222 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-28-2006 01:44 PM
formatting an audio drive joshuah777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-27-2005 07:48 PM
HELP... Audio Drive formatting problem Bug0711 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-13-2003 09:40 PM
Need help formatting dedicated audio drive MadeByNick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 03-06-2003 01:15 AM
A general question on audio drive formatting tld Tips & Tricks 3 08-04-2000 12:08 PM
