Old 03-01-2007, 09:18 AM
VictorQ VictorQ is offline
Default Mbox: analog part ok, no input in protools
Hello
I am a not so newbie, who recently dusted off the old mbox to do some electronica.
But alas, I discovered that I couldn't record audio!?
The unit is functioning as a playback engine, everything seems fine.
The preamp and monitoring circuit is good: I can monitor the signal from the mic.
The problem persists in all audio applications, suggesting a hardware fault.
My system is a Pentium 4 2.4 GHz. An old thing with a chipset specifically stated as not compatible with PT... But hey! It used to work just fine.
What can I do to fix it!? Please help me! The sound of the Mbox has sentimental value to me!
Victor Jupin
Old 03-01-2007, 09:38 AM
spkguitar's Avatar
Default Re: Mbox: analog part ok, no input in protools
I'm a bit confused; You say that you can monitor a microphone that is plugged in? This indicates no hardware fault; it seems to be working just fine.
Can you describe your process for setting up a track to record? Maybe we can point out something that you might be forgetting?
Old 03-01-2007, 10:46 AM
Well... Nevermind:
I installed the 7.3 drivers and the problem disappeared!
I was a software thing after all. Thanks!
Aux Input vs. Mic 1/Analog 1 Input (when using external preamp) xesands 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-26-2010 09:27 AM
how to patch the 8ch FoH analog input to protools. Audioartist VENUE Live Sound Systems 2 04-20-2010 11:42 AM
Mbox Input DEFAULTS to Analog? mu-tron-kid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-08-2007 10:04 PM
Protools Calibration Mode: low analog input levels SoundReplay Pro Tools TDM Systems (Mac) 2 03-20-2006 01:38 PM
Mbox Analog Input with Digital Output Alhuero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-27-2003 12:59 PM
