Automation when Bouncing???
Hi All,
How does one Bounce down to a Stereo Mix whilst capturing all of the Automation within the Session? Using PT 7.2.1, Session is at 96KHz, 95 of the 96 Tracks are being used. MUTES (On/Off), Volume chanes, PAN changes etc.... they are not working!!! Arrrggghhhhh! This should be possible right? Thanks for your time. Phill
I look forward to your response(s). Phill |
Re: Automation when Bouncing???
Hi Phil,
Please don't take offense but you are asking a very basic question on the operation of Pro Tools.... Have you read the manual ? All automation will work as long as you have all tracks in READ mode and you have have not inadvertently put it in auto suspend mode. Pull up your Automation Enable window and make sure the Auto Suspend button is not pushed. Try that and let us know if works. |
Instead of bouncing to disk, try recording back into your session. Assign all of the tracks that were feeding output 1-2 to a buss pair. Create an aux fader with your mix busses as it's input and it's output set to output 1-2. While you are mixing you can listen thru the final aux sub. When you are ready to print, assign the aux's output to another buss pair and record your mix on a new stereo track (with it's output assigned to output 1-2). This works better for automation.
STeve
macmandigital.com |
STeve
macmandigital.com |
Alas, I can confirm everything that Steve is writing.
Do some searches for BTD, PTD, PTT, etc. We’ve discussed the intricacies of symptoms and workarounds a few times. IHTH. .
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
Jeremy,
The old guys around here (myslef included) all remember when BTD and automation did not mix (no pun intended). We're accustomed to NOT using BTD on mixes or when there is significant or critical (dense) automation. Not that this can be quantified, proven or otherwise justified, in the current version(s), BUT -- old habits prevail. Not to mention, the added benefit of being able to RTD time-aligned to the session, makes for easy tv mixes, vocal up/down, etc... HOWEVER, BTD IN THEORY should still playback all auto settings. If not, something is not working.
--Jeremy |
One pass I recorded to an internal track, another I bounced to disk. I lined up the two passes sample accurate with the two pop. The bounced to disk track was noticabley more consistant in the mute accuracy than the internal recorded track. Go figure. Still this is not a test of a complicated mix on the edge. But it seems that at least with simple stuff Bounce to Disk might have an edge. They are clearly not the same. I wonder if maybe stuff gets fixed that they know is broken, but they don't make a big deal about it because it was never broken, if you know what I mean. What do I know? STeve
macmandigital.com |
Steve,
Did you have ADC enabled when you printed the BTD? RTD? I have not done this test at the frame accurate level in years... so it may be worth a 15 minute excersize on Monday... Like you, I have real-world "but the mutes were late..." experience with BTD going back years... so I simply avoided it for printing mixes... maybe they fixed it? I would imagine that delay compensation will be a factor in any apples for apples test.
--Jeremy |
STeve
macmandigital.com |
MIDI Automation to Audio Track Automation | BBKBB | Pro Tools 10 | 6 | 11-28-2012 01:56 PM |
Protools Automation to AAF Media Composer Automation | TommyT | Pro Tools TDM Systems (Mac) | 1 | 08-10-2011 01:40 AM |
Convert MIDI automation to audio automation | jnash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-21-2010 03:28 PM |
Bouncing in session first vs. bouncing straight to disk... | WATYF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-07-2007 03:17 PM |
Automation Quirk...I didn't Write any Automation!! | a2zproductions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-20-2005 10:34 AM |
