Old 08-09-2006, 08:20 AM
Aquarius Aquarius is offline
Default Absolute pan linking ? Help please...
Hi ,
Could someone please clarify the "absolute pan linking" stuff ?
Thanks,
A
Old 08-09-2006, 10:48 AM
SessionKat SessionKat is offline
Default Re: Absolute pan linking ? Help please...
Hi ,
Thanks,
A
Hi-level summary:
Pan-linking is now available in Mix groups in which the Pan linking is saved as a Group attribute.
"Use Absolute Pan Linking" is an on/off preference in the Perferences/Mixing pane.
With this pref OFF, linked panning control moves will be relative.
Example:
4 track Mix Group with Pan-Linking enabled.
1. With all tracks pan values at center, move one tracks pan control left/right and see other Group members' pan follow the same pan values.
2. With all tracks pan values at center, CTL (clutch) a track 4's pan slider to full right. ("Clutch" refers to temporarily isolating that control from modifying the other Group members).
3. Now move a track 3's pan which is at center position to the far right. You'll see other center-based tracks follow, though track 4 at full right position will not move, as it is already full right.
4. Move track 3's pan to far left position. Result: Tracks' 1-3 pan will go to far right, but track 4's pan should move back to center, as we've stored the relative offset of track 4's pan position.
If you now turn "Use Absolute Pan Linking" ON, and repeat the same steps, you will see (in Step 4) that Track 4's pan position will 'snap' to the other's position as we are now using "Absolute" instead of relative positioning.
Hope this helps.....
-tv
Tim vdB
Avid Audio
"There's a fine line between stupid and clever."
SC48 pops when linking or un linking stereo channels lorenaguey VENUE Live Sound Systems 7 07-16-2013 08:11 AM
PT 7 Absolute Grid? onimic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-22-2005 01:07 PM
Absolute best compressor / pre-amp under $500 wallsstreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 06-16-2005 04:27 PM
Firewire... The absolute best?? duende Pro Tools TDM Systems (Mac) 12 11-13-2002 09:25 AM
Absolute BEST CPU set-up for 001 imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-13-2001 11:27 PM
