Old 12-19-2005, 10:42 AM
kkoran kkoran is offline
Default Using PodXT with original MBox
I just got a PodXt for laying down guitar tracks in my home studio. Currently, my setup is an MBox running to Pro Tools 7 LE. I would like to know the proper technique for connecting the PodXT to the Mbox to get the best possible sound quality with the least amount of noise/hum/pops and other signal quality issues. These are the aspects I need assistance with, as I am fairly new to home recording:
-Do I need to use a DI Box anywhere in the signal chain?
-What kind of cables should I be using? balanced/unbalanced? (PodXT accept them both for outputs)
-Should I be plugging the outputs of the PodXT directly into the Mic/Line Inputs, or use the TRS jacks because the PodXT is considered "outboard gear"
-Which setting should I use for inputs on the front when coming out of the PodXT into the MBox, Line or Instrument, and does it depend on the cable I am using?
-Lastly, should I save all other effets and EQ processing (ie: verb, eq, compression) for mix down and just use the PodXT for my amp distrotion/mic/cabinet model settings??
Thank you very much, any help is greatly appriciated!!
mbox micro/podxt question MrPrime69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-03-2009 06:29 AM
Line 6 PODxt to Mbox 2 ??? *DELETED* No L 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-06-2006 11:29 AM
re-amping with a podxt and mbox jrm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-03-2006 02:04 PM
MBox and PodXT compatibility problems? leonardrock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-29-2003 02:25 PM
mbox and podxt R0b M 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-08-2003 06:20 PM
