Old 11-28-2005, 06:15 AM
NoGreatMan NoGreatMan is offline
Default Delta 1010LT Hardware Help
I am using a Delta 1010LT sound card in my Win XP PCI slot. Is there any way that I can use 2 Delta 1010LT's at the same time and have simultaneous inputs? (20 inputs)
Please advise. New user.
Old 11-28-2005, 08:32 AM
DigiTechSupt's Avatar
DigiTechSupt DigiTechSupt is online now
Default Re: Delta 1010LT Hardware Help
Most likely you will just encounter problems with this configuration - I'm assuming you're referring to using it with Pro Tools M-Powered.
PTMP will only see the first interface - having 2 of them installed you probably will see flaky behavior or crashing in Pro Tools.
Avid Audio Tech Support
Support FAQ
Old 12-01-2005, 03:07 PM
randi randi is offline
For years I have simultaneous used and enjoy my 2 Delta 1010s under "other" programs (name reserved) successfully and harmoniously. I always have had 16 Bus input to my PC. But I don't want to waste my money to buy PTMP because Digidesign decided to restrict simultaneous use of multiple M-Audio peripherals! Unfortunately, I can't do with only 8-Bus (one Delta 1010).
Why is Digi doing this - thats like punishing numerous customers who have multiple M-Audio peripherals? It's like if Digidesign supported multiple peripherals people won't buy the HD Systems? I can't think of anything else. But I can't afford those systems, probably will never afford at all! My domain is M-Audio Systems.
But I do hope Digidesign remove this restriction sooner, and I can finally move to PTMP.
Thanx
I love Pro Tools!
Looking to move to PC so I can use a Delta 1010LT jj5000 Pro Tools M-Powered (Win) 2 12-09-2009 06:42 AM
PT and Delta 1010LT ziggy1621 Pro Tools M-Powered (Win) 0 01-03-2008 06:26 PM
how can use all my delta 1010lt inputs in protools? HJKL Pro Tools M-Powered (Win) 4 07-15-2007 08:27 AM
Delta 1010LT and 10.4.6 jbmelby Pro Tools M-Powered (Mac) 0 04-23-2006 09:33 AM
Delta 1010LT cable estregan Pro Tools M-Powered (Win) 2 05-18-2005 09:40 AM
