plosive removal
What plug-in's (TDM) to remove Plosives (popping "p")?
Re: plosive removal
de-esser
Re: plosive removal
Bob
Save early and often! (or once a day whether you need to or not...) |
Re: plosive removal
Well, if you want to do it the hard way, snip out copies of the plosives to a new track and invert the phase.
Poof, plosive eliminated. A little EQ and plosives 'managed'. This has been discussed at length in previous threads on the DUC. |
Re: plosive removal
i agree with trakbytes, i have never gotten a de-esser to work on a P-losive.
to add another idea: slice the region just befor the offending "P" or "B" and do a quick ramp fade. that in combo with a hi-pass set above 90 (80, 100, 110, wherever) usually does the trick. in a horses have already left the barn comment, i'd say pull your pop screen back form the mic diapraghm a bit and carefully watch that talent doesn' push back in. i have seen voice talent come in a nd push the screen closer. and i ask them to move it back where it was. then i make sure that the mic and screen are out their way and they move the script stand where they need it. best pop screen i know of is the STEDMAN. they work great, but the early models scratch your mic stand arm wherer they attach. i think theyt have sinced fixed this. AND they are washable.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Re: plosive removal
I've been known to edit out the plosive part, leaving the beginning and end of the "p" sound, closing up the space and putting in a short crossfade. it's time consuming, but works a lot of the time. You can definitely see the offensive part of the waveform.
Re: plosive removal
(Bob said basically the same above. I should read before typing )
My fave is a high pass audiosuite filter with handles (100 Hz to as high as 250 Hz, 185 Hz is my default) tweak crossfades to taste. If I have lots of time (and budget) and several takes for each pass, I will grab matching non-popped consonants and replace. Tedius, yes, but yields the very best results with solid editing. Happy Thanksgiving! Go Cowboys!!! Frank |
Re: plosive removal
Use a Waves C1 or C4. Start with one of the bass compressor presets and tweak from there. Wave Arts has a great plugin also. Wave Arts MultiDynamics Plug-In
Re: plosive removal
A Waves C1 or a C4 for a plosive? I think you got some 'splainin' to dooo.
Mark Ettel C.A.S. |
How to get of the Plosive? | peter5992 | Post - Surround - Video | 17 | 02-21-2013 07:33 AM |
Armrest removal? | Drew Mazurek | ProControl, Control|24, Command|8 | 12 | 08-01-2006 08:50 AM |
mBox removal | Bender | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-27-2005 07:58 PM |
Click removal | soundeziner | Post - Surround - Video | 3 | 12-02-2004 12:33 PM |
OT Removal of Mac OS 10.1.5 | Stephen Bond | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-30-2003 05:00 AM |
