Old 07-30-2005, 12:03 PM
stu2469 stu2469 is offline
Default Scroll Options, Sends & Ruler views not working?
I have been watching the M1 DVD and it explains how to adjust the Scroll, Sends and Ruler views. The trouble is, that when I click on them in the menu or hover over the arrow or text NO other options are shown? All the others work and show their sub window, but these three do not. Which is frustrating as I am unable to set up protools properly. Is there something I am not doing.
Pro tools 002 LE 6.9.2
Mac 2.7 dual, 4gig ram, 400gb x 2 HD, Nvidia 6800 ultra.
Can anyone help?
Stu
Old 07-30-2005, 08:21 PM
yOkO yOkO is offline
Default Re: Scroll Options, Sends & Ruler views not workin
PT menu > operations > link edit and time line selection.
so what
Old 07-31-2005, 06:09 AM
Thanks, but no joy. Either checked or unchecked I still can't see the other menus?
Have tried both 6.9.2 release and the current latest revised release.
Anyone, any where can help?
Stu
Old 07-31-2005, 07:20 AM
Lampdawg Lampdawg is offline
Hey stu2469,
What is the M1 DVD?
Old 07-31-2005, 10:50 AM
It's an instructional DVD on how to use protools. You can get it from most pro tool dealers.
Just to add further frustration the Fader & Trim menu's are refusing to show the sub menu's too. So that equals the following submenus that I can't access:
Scroll Options
Sends Views
Ruler Views
Fader
Trim
All the above, I can't access the sub menu. I will hover over the main menu say Trim, but nothing will appear in terms of a sub menu, despite their being a triangle to suggest it should. On the Method 1 DVD it talks about Scroll, sends, ruler and fader options and shows them being used, but I can't do the same. Why?
Any ideas Digi?
Stu
Old 07-31-2005, 03:00 PM
Shawn Simpson Shawn Simpson is offline
Hmmm. I'm not sure exactly what you're doing wrong, but let me see if I can help.
I'm assuming you're referring to some options under the display menu (edit, mix, or send view shows), the operations menu (scroll options) and the edit menu (Trim and FADES). Is that correct?
First of all, make sure you're not playing back if you're trying to change the scroll options. Second, if you're trying to use the FADES or Trim functions, make sure you have an appropriate selection where those commands would be relevant. And finally, if these options are appearing selected when you hover the mouse over them, but the sub-menu isn't appearing, you might need to move your mouse a little to the right to evoke the sub-menu.
Old 07-31-2005, 06:28 PM
Thanks for the help.
For the fades I am trying to go to the submenu when I have a section highlighted between two cuts. With the others they should apparently show regardless. However with all of them, the triangle to the right isn't greyed out which suggest there should be a further menu. But when I click or hover over these no sub menu appears. It works fine with all the other sub menus so I know I am not doing something wrong with the mouse.
This is really frustrating me as there are many aspects of PTLE that I need to have access to. At the moment, with my sessions, I am unable to any fading, or change views, sends or anything like that with the sub menus which are needed. I have tried to re-install after removing PTLE, have also totally removed and re-installed from 6.7, upgraded to 6.9.2 (as my system is Tiger) and then tried again later with the latest upgrade.
Any one got any ideas as this is causing me severe problems and musician stlye angst lol!
Any help appreciated.
Stu
Ruler/playhead view options phillyt2k Pro Tools 10 0 11-29-2013 09:59 AM
changing sends assignment views jackp Pro Tools TDM Systems (Mac) 0 10-21-2012 10:13 PM
Feature Request: Change Scroll Options Without Stopping Carl Sealove Pro Tools TDM Systems (Mac) 17 03-08-2010 02:50 PM
Scroll Options JHJ Pro Tools TDM Systems (Mac) 3 02-28-2006 04:04 AM
scroll options and .... john1192 Pro Tools TDM Systems (Mac) 4 01-19-2005 02:59 PM
