Old 07-19-2005, 10:02 AM
soloan soloan is offline
Default Fading causing click sound(or Spark)
Hi. I am using Protools 5.1, TDM 24 mix plus system on Mac OS 9.2. I've just experienced a problem on Fading. Here is how it happened:
I have imported several sound files by "Import Audio to Tracks". Some sound files are SDII 24/48 while the others are wav 24/48. The protools session is SDII 24/48. When i import those wav files into the SDII session, I didn't convert them to SDII. I just leave them as is. No problems on mixing until:
I grouped several tracks together, including SDII and wav, and I fade out this whole group by pulling down the VOLUME FADER. During my manual fading on a Mackie HUI, it sounds fine. BUT WHEN I LISTEN TO THE PLAYBACK, IT'S GOT A CLICK SOUND IN THE MIDDLE OF THE FADE. I checked all the tracks' waveform. There is no clicking on those grouped tracks and no edit point either.
What's the problem? How can I solve that?
Old 07-19-2005, 01:42 PM
Seeee Seeee is offline
Default Re: Fading causing click sound(or Spark)
delete your "digisetup" preference file and/or import tracks into a enw session or better yet.... save session copy in and make sure ya "copy source files"
Old 07-20-2005, 10:55 AM
Tried "Save a copy in" with all the audio and plugin settings regenerated in the new session copy. It's got the same problem. I'll try deleting the digisetup tonight.thz
"Pre-fading" snare sound nickmadsen The Drum Room 3 10-05-2012 03:22 PM
Sound Fading In and Out / Overheating ER? vkaxeman Eleven Rack 3 08-30-2011 10:29 AM
Panning a sound to create a fading effect Cayotic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-14-2005 09:52 PM
001 sound input for Peak/spark aps. gnaylor Pro Tools TDM Systems (Mac) 0 06-18-2000 06:37 PM
TC/Spark vs. Sound Designer II Dave Gehlhar Digidesign Hardware & Software 0 02-03-2000 02:09 AM
