Old 05-22-2005, 05:55 PM
joeldavidlauver joeldavidlauver is offline
Default my sound replacer makes the samples sound higher
i just bought sound replacer and installed it to my ilok but when i authorize it all the sounds are an octave or two higher then they should be. how do i stop this from happening? i've tried to reinstall sound replacer and taken out the files from digidesign folders. this makes no sense.
Old 05-22-2005, 07:50 PM
Default Re: my sound replacer makes the samples sound higher
Are your samples the same sample rate as the session?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 05-24-2005, 07:59 AM
sirgarz sirgarz is offline
With SR you need to make sure your session and samples have the same sample rate. It sounds as though your session is at a higher sample rate than your samples.
Drum samples for Sound Replacer Blackers The Drum Room 9 02-12-2018 05:06 PM
help using DFH2 samples with sound replacer plugin mach-1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-04-2005 08:06 PM
Need samples for Sound Replacer tommyj1112 General Discussion 2 09-08-2004 03:12 AM
How do i load samples into sound replacer Kevin P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-29-2003 05:20 AM
Sound Replacer Drum Samples XCLAIM Tips & Tricks 27 03-02-2001 12:26 AM
