Old 04-25-2005, 02:18 PM
stickytapenrust stickytapenrust is offline
Default sample rate conversion
Hey guys I just upgraded to HD. My old system was a 002 with ADATS... One session was recorded at 44.1 with the external Adat set to 48K... Now I have my Apogee converters and can't seem to get the sample rate back... The session is playing too SLOW... I can't seem to set my converters to a different sample rate than my PT session. My Session is at 44.1 and I need my clock to be 48... Are there any tips on converting? What can I convert to? to make it play...? Please Help...
Mac Dual G4 1. GHz
1.25GB Ram
PT 6.7
OS 10.3.5
AD-16x
DA 16x
Rosetta 800
Old 04-25-2005, 04:24 PM
DigiTechSupt's Avatar
Default Re: sample rate conversion
In the Pro Tools Workspace window (Windows>Show Workspace) locate the audio files that were recorded at the wrong sample rate and, in the Sample Rate column, change the SR to 44100. Then create a new session at the correct (48 k) sample rate and import the audio files, or use 'Import Session Data' to import the tracks into a new session.
The problem is that the files are 'tagged' at the incorrect (44.1k) sample rate - they're recorded at 48k (slaved to ADAT), but tagged at the Pro Tools session sample rate. You need to correct the tag, then import them into a session at the correct sample rate or SR convert them into a session at 44.1k.
Avid Audio Tech Support
Support FAQ
Sample rate conversion? meathman Pro Tools TDM Systems (Mac) 10 05-19-2007 05:09 AM
sample rate conversion stickytapenrust 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-25-2005 02:20 PM
sample rate conversion D Clarkson Tips & Tricks 13 04-15-2003 10:38 AM
Sample Rate Conversion ThreeBlake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-08-2002 12:55 AM
sample rate conversion dj buttnaked 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-06-2002 03:17 PM
