Old 07-20-2004, 11:34 AM
Voxer Voxer is offline
Default Error: \"Logical end-of-file reached\" -39
I've started using the "export as files" (shift-apple-K) function lately, as opposed to bouncing-to-disk. Saves time and money. Usually. Once in a while I get an error message right after the function finishes. I'm finding it has to do with whether or not I edited the region and whether I renamed it before trying to export.
Seems to be one of those hard-to-pin-down errors. Anyone know anything about it?
Thanks,
Dave
PT 6.4
CA 6.5.1 (which I LOVE)
G4 1.4Ghz
Pacific Pro External Firewire 80G
Old 07-23-2004, 10:50 AM
Default Re: DIGI HELP \"Logical end-of-file reached\" -39
I am losing time and money because of these errors: -9035 and -39. They descend upon me whenever I try to "export as files" (shift-apple-K). If I name, edit or even move the region before doing this function, I get an error -39. If I then try to bounce to disk, I get -9035. If I restart ProTools, I LOSE THE FILES.
Please. Help.
G4 1.4Ghz
PT6.4
CA 6.5.1
External firewire drive +HFS extended
scanned/defragged
Old 07-23-2004, 10:59 AM
west audio west audio is offline
I stumbled across something similar while working on a slower machine. If I consolidated a range of clips and then renamed the consolidated clip before the new waveform was drawn, I would get error messages simlar to what you're describing.
Glen West
Old 07-25-2004, 12:00 AM
Avid's Avatar
Avid Avid is offline
Administrator
Pro Tools 6.4cs5 (both LE and TDM Mac versions) linked at the top of this forum and the Downloads section fixes a number of causes of 9035 errors. If you have not already done so, try updating to that to see if it helps. This update is recommended for all Pro Tools 6.4 LE and TDM users.
Administrator
"logical end of file reached" - error opening an older PT 5 Dopamine Pro Tools TDM Systems (Mac) 3 02-10-2008 12:37 PM
Error code -39 Logical end of file reached?? vanhanson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 08-15-2006 05:55 PM
Logical end-of-file reached (-39) Igotsoul4u Pro Tools TDM Systems (Mac) 5 06-09-2005 06:26 AM
Reached logical end of file -39 Giles Pro Tools TDM Systems (Mac) 4 09-18-2003 09:28 AM
Logical end-of-file reached (-39) yeshe337 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-06-2003 10:13 AM
