Old 07-06-2004, 11:29 AM
E-an E-an is offline
Default PT 6.4 and 6.1 compatability
Just a quick query...
Is it necessary to export a session from PT 6.4 to enable it to load on version 6.1 of protools or are they directly compatible ?
About to start working between two PT setups and one has PT 6.4 and the other has 6.1! Not having used 6.4 I thought I'd check!
Many thanks,
Iain
Todays posting was brought to you by the letter e
Old 07-06-2004, 11:31 AM
Default Re: PT 6.4 and 6.1 compatability
Every session after 5.1.1 is interchangable and you can open it on any version of Pro Tools after 5.1.1
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 07-06-2004, 10:58 PM
roberts roberts is offline
Any faders above +6 will not translate (6.4 session can do +12 on all faders/sends) - but everything else should be OK
Compatability TDM 5.3 with LE 7 artsoul Pro Tools TDM Systems (Mac) 0 05-13-2007 04:50 AM
PT 7.x.x Compatability with PT LE 5.1.1 Clancy Wiggum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-11-2007 08:56 AM
PT LE 6.4 Compatability with 10.3.9 andrewnicols 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-19-2005 04:52 PM
Mac/PC compatability kinglenario Pro Tools TDM Systems (Mac) 9 07-10-2004 07:51 AM
compatability maslusher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-25-2002 01:33 PM
