Mbox2pro --> monitor out static / feedback noise
This has been an ongoing problem basically since i got the mbox2 pro new. The right side monitor output produces a constant static like noise no matter what the volume knob is set to. I have tried swapping cables to no avail. I switched the rightside speaker cable into the left output and the noise went completely away. When plugging the leftside speaker cable now into the right output, the noise came back through the left speaker. So the speakers are not the problem it looks like. I have tried different firewire cables and also connected my headphones to monitor outputs with an adapter and still heard the noise in the right speaker of the headphones.
About 3 months ago i sent the mbox back to digi for repair. After six days of testing they said they were unable to reproduce the problem so no parts were replaced. The problem is clearly there as its a constant annoyance everyday. I should also add both the headphone outputs are perfectly quite. So as a workaround i have been using a Y adapter with the two monitor cables and running them into the second headphone output. This has worked and been noise free. I would however like to get this issue resolved so i don't have to rely on using one of my headphone outputs. Anyways any info relating to my problem would be appreciated. Whether its possibly a grounding problem or bad capacitor, any feedback would help. |
Re: Mbox2pro --> monitor out static / feedback noise
bump... still looking for help on this one :)
General Troubleshooting - Pro Tools LE and HD on Mac OS X Read through this, follow the trash prefs guide in the middle. But there are some things you should follow in here anyhow. Good luck.
Absence of evidence is not evidence of absence...the truth is out there. |
I tried all these suggestions a good time and had no success. I truly think its a problem with the mbox.. anyone else :)
I do have the exact same problem, only I can still here the distortion/ static through the headphone as well. It's in the right side only. This actually was my excuse to change my 5 years old event monitors thinking they might be the issue. Now my brand new yammy hs80s have the same noise issue. It has to be the mbox.. Any solution anybody??
Bit of a long shot, but I used to get static when my USB or FW cable wasn't plugged in properly..
MBox 3rd Gen Mini making static/distortion/feedback during vocal recording | Duckett | Pro Tools 9 | 1 | 01-09-2013 09:11 PM |
Please Help! Feedback/Static before, during and after recording! | Ezavala87 | Pro Tools SE and Essential (Mac) | 1 | 07-10-2011 07:00 PM |
Studio Monitor feedback...CPU noise???? | Leify | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 12-25-2010 02:37 AM |
Static noise from speakers when turning monitor knob? | Yodah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-18-2007 08:05 AM |
noise bursts with mbox2pro | frabo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-06-2007 12:38 PM |
