Clocking DA-98 to 192 Digital/TDiff
I can't get my DA-98 (non HR) to work with a 192.... [img]images/icons/rolleyes.gif[/img] How do you hook up both devices ? Do I need to connect the World clok from the SYNC I/O, although I do remember TDIF-1 carries a word sync ? On the front panel of the DA, which clock ref should it be ? I've tried different ways but nothing seems to work.....Help please [img]images/icons/confused.gif[/img] |
Re: Clocking DA-98 to 192 Digital/TDiff
That should do it. Make sure the terminator is 75 ohm. Craig |
Hi CPettigrew,
But then how do you pass the clock to other devices ? [img]images/icons/shocked.gif[/img] |
TDIF does NOT carry clock signal. When DTRS machines are locked together the clock signal is on the SYNC cables. You have to use an external clock to run other equipment with it. We are using DA-78s with our 192s and I always run word clock from the Sync I/O to the DA-78s and don't have a problem. As for running to other devices, you either get a BNC "T", loop through the DA-98, or get a workd clock distribution amplifier. I hope this helps.
Now, for my second DA-88, you'd think that a BNC from my second 192 to my second DA-88 with termination would work. But it does not. As the second machine is a slave, (and Tascam being Tascam) I take the Word Clock Out from the top DA-88 and go to the Word Clock In of the second DA-88. No need to terminate the second machine. All works and clocks well. I f I needed to clock anything else, I could then use the Word Clock Out of the Sync I/O or the second 192. (I use Blackburst to Video Ref In, and then use Loop Sync to clock my system) Craig |
Aggregate IO clocking errors digital distorion | Dhammer | Pro Tools 10 | 2 | 10-07-2013 02:47 PM |
MacBook digital out not clocking w/ Central Station | KenSluiter | macOS | 8 | 06-19-2011 05:27 PM |
questions about clocking sc48 to other digital devices. | Zackdh89 | VENUE Live Sound Systems | 3 | 08-24-2010 09:12 AM |
Clocking multiple Digital devices with 002R | rpyrotech | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-11-2010 08:02 AM |
Clocking confusion: Digital Sync vs. USD | Baixo | Pro Tools TDM Systems (Mac) | 3 | 11-05-2001 04:55 PM |
