Strip Preamp with Mbox problem
I just bought a Presonus studio channel preamp. It is tube driven and has comp and eq adjustments. I was told that I could run it straight through the mbox without problems.
SO i have tried a few vocal takes with the thing using the eq and comp and also without the comp and I am running into distortion problems. I record at a good level without any clipping and yet the final recording comes through sounding like it is clipped. scratchy/static sounds I am using the phantom power from the preamp since it is a condenser mic and I found that turing up the gain on the mbox makes it much worse. Any Ideas??? |
Re: Strip Preamp with Mbox problem
Im not using a line input it is a condenser mic.
XLR Is a balanced input anyways right? |
A preamp usually puts out a line level signal that needs to be routed to the mbox line input as Craig F replied. Regardless of what mic is plugged in.
Except for certain digital inputs, XLR is a balanced input.
OSX10.6.8, 1st gen Power Mac, PT8.0.5, Mbox2 |
sorry I stopped short
Line input of the mBox which is the 1/4", the XLR on the mBox is mic level input
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
New Mbox Pro problem with preamp pots? | Hey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 11-11-2014 05:38 PM |
Preamp / channel strip | Bender | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 11-11-2008 08:15 AM |
Channel Strip to MBOX | vicster20 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-09-2005 03:24 PM |
Mbox preamp/ new preamp | Antihero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-23-2003 07:31 AM |
002 scroll strip problem? | Calvin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-08-2003 06:30 AM |
