SideChains
Hi
I am hoping that someone would be able to help me out with this. I want to put a gate on my bass track and to have it triggerd by my kick track using the side chain fin the gate. example; My kick is on track 1 with the input set to bus one and the output set to my interface 1 & 2 The bass is on track 6 with the input set to bus 1 output to interface 1&2 when i look in the key input on the side chain i see list of the busses my question is which one do i choose so that the kick can triggered my bass track, using the sidechain on the gate. yoour help will be gratefully appreciated. Thanks in advance. PS:I am using the Mbox2 with protools 7.3.1 |
Re: SideChains
Hey man,
If you want to sidechain you need to send some kick signal to the gate on the Bass track. put a mono send on the kick track (probably pre-fade, so you won't mess up your gate settings by moving your kick fader at a different time), use bus 2 if you're already using bus 1 for something. then select the gate on the bass track. enable the key trigger, and select bus 2 from the key source drop down menu. now if you hit your key listen button with the bass track solo'ed, you'll here the kick in the gate rather then the bass guitar. set all your parameters accordingly and your good to go! let me know if that helped at all, PS what where you hoping to do with the gate on your bass? gating all the bass note except those which fall on a kick hit? I'm just curious as normally people use a compressor on the bass to reduce the level slightly when the kick hits, to separate them a bit without excessive eq. the gate (or maybe an expander) would be a cool idea to try...
Evan Click me... MacBook Pro 2.8 GHz intel i7, 16GB / OSX 10.10.5 / PT 11.3.2 / UA Apollo |
ADC, sends and sidechains | wyman | Pro Tools HDX & HD Native Systems (Mac) | 7 | 02-11-2015 05:47 PM |
Calculating correct offset for sidechains sends - anyone know how? | mr xy | Pro Tools 10 | 0 | 04-18-2013 12:34 AM |
SideChains | spidey901 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-12-2007 10:56 AM |
STRANGE LATENCY PROBLEM WITH SIDECHAINS... | nrsv40 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-16-2007 02:10 PM |
Talkback - Gates, Comps, and Sidechains | Jburn34 | Pro Tools TDM Systems (Mac) | 15 | 03-05-2004 11:15 AM |
