Quantizing
Hi everyone a newbee here.
Could someone please explain to me what is quantizing and how it works, I am under the impression that it suppose to correct your timing after recording, I would greatly appreciate someone explainig to me how it works, thank you in advance |
Re: Quantizing
That'a pretty much what it does, it corrects timing. Lets say you're playing keyboards and you're just a little bit off on your timing, Quantize will move the notes to whatever parameter you set it to, such as quarter note, 1/8 note, 1/16, etc. You can also change the percentage of correction so that it doesn't have such a robotic, mechanical feel. This just saves you the time from having to go in and move notes (like you can in the MIDI environment) or trying to separate the notes and moving them individually.
Hope this helps a little, Dan'o |
Re: Quantizing
thank you very much, it most certainly help, so all i have to do is set the parameters before i start recording is that correct? this works on any instruments i record? ex. drums, bass, guitar, right?
Re: Quantizing
one more thing when should the parameters for quantizing be set, before or after i record
Re: Quantizing
If I remember correctly, it can be before or after. If you have it on before, it will quantize it as you record, you just have to make sure that the note value that you're using is correct (1/4 note, etc) or you can listen to the recorded info and if there's something you don't like, you can hi-lite it and quantize it from there.
Dan'o |
Re: Quantizing
Spidey one point about your earlier question.
Quantizing as has been explained is done for midi or instrument tracks only. Where you have recorded pure audio into your session such as guitar, bass, mic'd drums etc you can't quantise this. Although I do understand beat detective allows you to do something similar for audio in PT. Someone else may be able to explain that as I haven't used it. This likely works best on drums however due to the defined and consistent transients that can be mapped compared with guitar or bass. |
Re: Quantizing
"[QUOTE]
Spidey one point about your earlier question. Quantizing as has been explained is done for midi or instrument tracks only. Where you have recorded pure audio into your session such as guitar, bass, mic'd drums etc you can't quantise this." Opps! My bad.. I must have brain farted when I wrote earlier (too many things going on at home, sorry). Yes, he's definitely correct, Quantize is for MIDI only. Dan'o |
Quantizing twice? | Mahkyb | macOS | 2 | 02-06-2012 09:33 AM |
Quantizing - Need Help | fastdog | Pro Tools M-Powered (Win) | 2 | 10-02-2010 12:05 PM |
Quantizing HELP! | M A T T | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 02-01-2003 06:13 PM |
quantizing | Jason Locklin | General Discussion | 1 | 12-24-2002 01:25 AM |
Quantizing in PT | Melodymaker | Pro Tools TDM Systems (Mac) | 7 | 09-08-2001 12:46 AM |
