Old 09-13-2004, 08:01 AM
jordan23 jordan23 is offline
Default Serato - Pitch N Time (Quick Question)
Hey guys -
I've been checking previous posts listed and the final answer hasn't been given yet -
Just curious if the DEMO version of Serato's PnT is supposed to produce a "flangey" sound on purpose - I'm thinking yes - Cause this isn't the final (bought) version - In my case, this happens when 8 tracks of drums are highlighted even in preview mode - A "swoosh" sound is created (I've tried all the multi / mono functions already) - If you move the BPM only 1 less or 1 more the sound becomes even more noticeable - Anyone have any insight on this?
Thanks...
Old 09-18-2004, 12:51 PM
Jace Everett Jace Everett is offline
Default Re: Serato - Pitch N Time (Quick Question)
I never had that problem with the demo.
My only problem is I love the plug, but can't afford it!
Are you using it as an actual plug-in or using it to audiosuite files?
Mac Pro 2.4 Quad, 8 Gig RAM Snow Leopard 10.6
HD Native PT 10
Omni
Waves Platinum
NI Komplete 8
API 512c, LA 610
Some Mics, Some guitars
Some Songs
Old 09-18-2004, 10:45 PM
Bhennies Bhennies is offline
Hey guys -
Thanks...
hey there, I haven't used serato pitch and time, but I use the waves time compression plug, and when pushed hard enough, it does the same thing. It's very difficult to get a bass line or hi hats to speed up while keeping the same pitch, imagine trying to squish the waveform while keeping the frequency the same- you're bound to have some artifacts. I've noticed that the most I can push my stereo tracks with the waves plug is 4-5 BPM (about 4 percent at the BPM's I use- around 80). Forget Digis time compression plugin- even pushing it 1 BPM sounds like your underwater.
p.s. sorry not to answer your original question but I thought this might help.
Digi 002R, RME 8 i/o, DP 4.5, PT LE 6.4
Old 09-19-2004, 07:41 AM
kite kite is offline
Pitch n Time is truly amazing, and worth every penny ( or Cent for you Yanks !) -
Best way to use it I suggest, is not to try to process 8 tracks in one pass, but to always work either on a single file, or a stereo mix.
So, with your drums, bounce to a stereo track, and try processing that. Don't know about the Demo though -check with Serato !
I use PnT loads, for either small adjustments to loops , or even to lengthen a solo piano piece -it is truly amazing, as you cannot tell that any Time processing has been applied; however, stupid amounts may give some artefacts. For sensible adjustments, it's got to be one of the best, expensive, but it's paid for itself many times !!!
www.kitestudio.co.uk
Mac Pro
Snow Leopard
003 & Midas Venice desk
Mindprint DTC
Soundelux U99
Drawmer M-Clock
Serato Pitch 'n Time 3.0 is out Buccanears AAX Plug-ins 24 12-31-2013 02:57 PM
Serato - Pitch 'n Time 2.2 -- HELP emelare 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-20-2006 11:19 AM
Serato Pitch N Ttime (Quick Question) jordan23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-13-2004 09:00 AM
Serato Pitch N' Time iamspooky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-04-2004 05:58 AM
serato pitch n time gdubbs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-05-2001 10:15 AM
