Old 10-14-2012, 03:45 AM
Herokazz Herokazz is offline
Default Problem when record enabling stereo tracks!
Hi
Im having a very annoying problem. If i have a mono track for vocals for example and put a mono-to-stereo plugin on that track the right side seems to be delayed quite a lot when record enabling it. It is impossible for the artists im tracking to sing with such an effect on. It doesn't matter if its avid's own plugs or third party.
I have to remove the plugin completely for it to stop. Not even making it inactive helps. And then put it on again when we're done recording.
Sends are ok. It's when the meter on the track changes from 1 to 2 bars...
Any suggestions??
Old 10-14-2012, 11:46 AM
soybalm soybalm is offline
Default Re: Problem when record enabling stereo tracks!
It sounds like your interface, whatever it is, has direct monitoring on. Turn it off from it's interface control panel. You need to supply more info about your gear so maybe someone with similar gear may see your post. Also you can go in the setup menu i/o and select defaults for everything and see if that helps. Maybe you can turn something off there.
If I'm not mistaken, PT has a limitation where you can't turn off software monitoring but there are workarounds for that.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 10-14-2012, 03:11 PM
Beyond that, I would not use a mono-stereo plugin on a vocal track during recording(probably wouldn't anyway). Assuming you are trying to use reverb while you track, add a stereo AUX send to the vocal track(select an open bus pair). Create a stereo AUX track, set the input to the same bus pair, insert your reverb plugin and adjust the amount of verb with the AUX track fader. In general(as there are no hard rules on this) delay and reverb effects would be used with sends and AUX tracks as I just described.
Old 10-17-2012, 01:08 PM
Can't you see my gear if you go to my public profile?
Anyway I have a digi002.
I forgot to mention one thing though. I have never had problems with this in PT 8 before i upgraded to PT 10... So i don't think it is a direct monitoring thing. I have never heard about that??
I use sends as well a lot. But sometimes you just want a specific delay for one vocal. Or you just wanna put some chorus/fazer/doubler on a guitar/vocal whatever. I can think of many reasons where it doesn't pay to make a send. So that is definately not a solution for me...
Any other suggestions? Anyone?
Old 10-17-2012, 06:09 PM
cwsand's Avatar
cwsand cwsand is offline
Probably, but not everyone is going to go to that trouble so it's best to post your info in the thread.
Maybe a link to a screen shot of your mix window would help. Never had this particular problem myself.
Help Us Help You
Chris
Pro Tools 2024.10.1
MOTU 24Ao
Focusrite LS56
UAD Apollo 4X Heritage Edition
Avid Artist Mix/Control
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 10-19-2012, 05:34 AM
I have just found out that the problem disappears when I turn off delay compensation... :/
Win 7 64 bit - service pack 1.
i7 quad core 3,4 ghz
4 gb ram
Pro Tools 10.3
Digi002 rack
Record enabling multiple tracks joshfrog94 Pro Tools 9 2 11-14-2010 12:33 PM
record enabling a group of tracks lululu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-05-2009 08:40 AM
LOUD Click when record enabling tracks in 7.3 cfb25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-14-2006 06:46 AM
Record-enabling tracks turns automation inactive CHD Post - Surround - Video 4 04-05-2006 07:26 AM
Record-enabling several tracks at once j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 03-05-2002 02:32 AM
